Non Hybrid 2024 ORD Starting Issues
Romer
Romer
Ken
Centennial, CO
I thought it was the loose terminal, but terminals have been tight since I discovered it a few weeks ago and clean
gpburdell
GA
3G Tacoma
My experinace with batteries has shown that cell problems relating to current can be intermittant and not show up as voltage problems. These are harder to isolate due to chemical. temperature and other factors
Yeah, that's where a proper load test is helpful. A failed battery might show a moderate open-circuit voltage, but suffer severe voltage drop when a load is applied. (I've experienced that once)
Romer
Romer
Ken
Centennial, CO
The dealer tested the Battery and said it was good. That has happened before with a bad cell over my years of auto ownership. An intermittant cell issue doesn't always manifest during a test.
I had them replace the battery anyways on my dime. They ended up putting a better True Start 00544-H7EFB-TS 760 Amp vs the stock 395LN4-MF 689 Amp it came with.
When it failed, no starter cranking, but everything else worked and battery voltage was over 12V when it failed to start at least two times. Waiting an hour to retry or jumping it resolved the issue. The retry (after an hour) was a quick start, not a slow crank you would expect with a low battery. To me that says an intermittant current vs voltage issue. Current issues with normal voltage tend to be cell related.
Nothing in the electrical configuration has changed since I installed the GRMS radio in early June. We have been gone a few times for several weeks over the summer while it sat without issue. I have been driving it pretty regurlay over the last couple of months. It is in heated garage when it isnt being used.
It is possible it isn't the battery, so at least I have ruled something out if it happens again. I also believe the measurements and behaviour show it isnt a parasitic drain. I believe it was the battery, but only time will tell.
32spoke
Jason
Petaluma,CA
Each cell contains 2.11 volts. Perhaps check the output terminal of the alternator for voltage while the engine is idling, should be in the 13-14 volt range, then immediately test the battery voltage with the engine running, should be the same. A battery that discharges from 12.65+ volts down to 12.4 volts will begin to degrade from the lead plates sulfating
Yotota
SW WA
24 TRD
Just to clarify...
You have cleaned both terminals and battery posts with a battery brush, and torqued the terminals to spec? And you've still experienced the starting issue since then?
Your issue sounds just like what I experienced, so I'm curious what else it could be. Once I started cleaning the terminals every oil change the issue stopped.
Romer
Romer
Ken
Centennial, CO
Alternator voltage was correct. You are correct it a Cell outright failed, it would drop around 2V. That is not what I am theorizing An intermittent failure due to a cracked connection would limit current without a significant voltage drop. I am theorizing that the intermittent issue is temp related. More likely when the battery gets to a certain temperature, but not above or below it. The temp effects a small crack to open enough to be an issue
I have seen multiple hard to define failures in building spacecraft over the years that have a similar threshold window for failure that you couldn’t understand the cause until you dissected the component in a failure analysis lab. These all ended up being mechanical in nature impacting a fatigue point within a certain temperature threshold.
Here is the data I had:
  • Fully charged the battery went to 12.7V and stayed there over several days of testing
  • When the failure occurs, it is at 12.1V when not trying to start
  • After the failure and driving for a while, the battery resting in my garage was at 12.4V and I could not make it fail
  • The failure does not occur when it has sat for days or in the cold
  • The failure occurred after a 20 minute trip
  • All the other electronics worked fine, no starter activity occurred
  • The failure wouldd go away after the truck sat off for 40-60 minutes and would start right up.
  • I tried the short trip and stop in my garage and was unable to recreate it
  • After the failure even after driving for an hour I would hook it to my battery charger and it would show 2 out of 5 bars for the charge level even while showing 12.4 v then sitting in my garage
  • The Battery passed the test at the dealer, but:
    • An AGM battery can pass a test but still be bad because tests miss intermittent issues, internal cell problems, or sulfation; the battery might work under a simple load but fail under real-world stress (like extreme temps, high accessory drain, or vibration) due to faulty cells, bad connections, or needing a full recharge/rest period before testing, even if it reads 12V but lacks Cold Cranking Amps (CCA) or drains quickly after the test.
If it was the charging circuit or a parasitic draw, I would think resting (and cooling) would not make it work again like a fully charged battery
I could be all wrong and it could be a charging issue or something else. I had no data to indicate that so I did the easy thing in changing the battery. It was the easiest thing for me to change in troubleshooting, true it cost $$, but moving forward trying something is always better to me.
I do appreciate all the comments. They are all valid Battery troubleshooting items and I am not ignoring them. Right now, the data with my engineer brain has led me down this path. Maybe I will be wrong, BUT I will have learned something by swapping the battery. I am not afraid to be wrong. It is part of the learning experiance.
Just to clarify...
Yes, But I replaced the battery so thinking it is resolved. Time will tell.
32spoke
Jason
Petaluma,CA
If you continue to have this darn problem, find some way to view alternator voltage while driving, not off the dash, but an independent gauge.. perhaps the alternator is intermittently not charging, if so.. is it receiving a faulty signal or is something bad within the alternator? Good luck and hope the problem has been resolved with your replacement battery
Romer
Romer
Ken
Centennial, CO
Good suggestion. I do have the OBD monitor capabilities. I will look to see if that will do what you suggest if it fails again
Romer
Romer
Ken
Centennial, CO
It has been a month with a new battery and no issues. So I have concluded it was an intermittant battery failure. One that did not show up during the battery test because it wasnt in a failed condition at the time
Romer
Romer
Ken
Centennial, CO
Well this happened again and left me stranded. Here is how I documented the issue to the dealer
The first time was Dec 2025. It did start again after 4 hours of trying. I brought it in and your techs could not recreate it. A bad intermittent battery cell could have been the issue so I replaced that at my own expense since you couldn’t make it fail. I was told to bring it in while it is in the failed state if it happens again. I did that last night as I made sure it was still failing when the tow truck driver unhooked it, but unfortunately after the techs pulled it in this morning it started up.
Yesterday, I drove 20 miles to take my wife for her cancer treatment. Afterwards we tried to leave at 11AM and the truck wouldn’t start. I checked the Battery cables (Tight), I checked the voltage (12.6V), I tried to jump it with my NOCO Battery Booster and no joy
  • No codes
  • No error lights
  • Everything else worked
  • It recognized the key FOB
  • It said “press brake pedal and press start” and when I did that, the message went away
  • I could see the Brake lights come one, so it would not be the Brake Sensor switch that enables the start
I called AAA and they came out to test and try to jump the battery. They said the battery was good and jumping did not do anything. At this point I sent my wife home in an Uber
Since I was on the 2nd floor of a Parking Garage with low clearance, I was told it would be a 6 hour wait for a tow truck. I tried to start it at least twice an hour
The Tow truck driver came and said he couldn’t get into the garage due to clearance. So I used my winch to pull/push the Tacoma down two levels of the garage to where to tow truck driver could get me. I had the truck “On” (no engine) to use the brakes. This discharged the battery, it was fine before when AAA did a Battery test. The battery was not discharged until I had to use the winch.
The Tow truck driver took me to AutoNation and I verified it was still failing.
This morning when the tech went to look at it, it started right up
The tech sent me a video saying I was concerned about the battery and it was discharged but still good. I am not concerned about the battery and I explained using the winch is why it was discharged
Reading through the factory service manuals I see the following potential causes defined by Toyota:
  • Starter Relay
  • Starter (likely solenoid)
  • Neutral Safety Switch. I did find a few videos saying this is a problem on some of the newer trucks
  • ECU Handshake
  • Immobilizer issue
  • Brake Pedal Switch - Verified vrake lights working
This fairly new vehicle with 7000 miles has left me stranded twice now for the same issue
The dealer has not been able to recreate it and the first time I replaced the battery at my own expense
They wanted me to come get it.
I needed to do something to at least rule some things out
I asked them to replace the Nuetral Safety switch, I am paying for that;. It wouldnt start in any gear FWIW
I will replace the Starter Relay
I will look at options for the Starter. They wanted $750 install price for the starter and are charging $360 for the part. I can get the same part from Sparks Toyota for $158 delivered
I have changed several starters in the past, but I read (not sure where) you have to take several things off to get to the starter and its a pain. Anyone here know the details on this part install?
I also found this today online, wish I could have tried it yesterday
Use the Emergency Start Override
Toyota includes a hidden override mode to bypass brake switch or sensor errors.
    • Make sure the truck is fully in Park.
    • Keep your foot off the brake pedal.
    • Press the start button once for accessory mode, then press it a second time to turn on the dash lights.
    • Press down hard on the brake pedal.
    • Press and hold the engine start button continuously for 15 to 30 seconds.
Well, if it fails again I will be able to rule out the battery, Nuetral Safety Switch, starter relay and maybe the starter if I get to that
Can you still jump these starters with a screwdriver?
Not sure how to troubleshoot an ECU issue. I did disconnect the battery for a minute, wouldnt that have reset the ECUs?
Will721
Will
Quad Cities
2025 TRD OR
Should be able to still jump a starter with a screw driver, which is what it sounds like is the problem to me. If you see a load "lights/dash dimming" but no start with cables, its most likely the starter. It also explains the lack of ability to repeat next day as they can have a tendency to fail with heat soak. A good long in town drive may be likely to replicate. However if it is the starter, you're hosed because no jumping fixes that.
Romer
Romer
Ken
Centennial, CO
This doesnt look too bad to remove/replace the starter. Anyone done this?
I am having the dealer replace the Neutral Safety switch and I just ordered a starter and starter relay to swap myself ALL at my expense since the Dealer hasnt been able to make it fail the two times they had it.
I need to do something rather than just waiting for it to fail again
Romer
Romer
Ken
Centennial, CO
After two weeks Toyota came back on 10/9 and said I would need to have the dealer run a diagnostic without the aftermarket stuff (Radios connected to the battery) and I would need to pay for it unless it found something. I said I see no value in running a diagnostic a third time and was not willing to pay $150 since I am confident it wouldnt find anything. And if it didn't find anything Toyota wouldnt pay to have the starter replaced, they wouldn't comment on that without the diagnostics
So I added the following to the case file since they will be closing it
I understand you are following a checklist and have no choice in you position. Had you enlisted a Technical person to review my information I am confident they would have agreed. There really is no value in running the diagnostic a third time. It was run in Nov 2025 after this first failure and the battery was fully tested as good and fully charged. There was not a concern about the aftermarket items raised at that time. It was ruin in Sept 2026 after the 2nd failure. The tech raised the aftermarket items because the battery was low, but I have fully explained I had to use the winch to get the truck to where it could tow me to the dealer from the parking garage. The battery was not low during the first failure.
The dealer understands the technical reasons why I think it is the starter, but they can’t replace it under warranty without a hard failure or authorization.
After our call I talked to the Service Director at the Dealer. I went over all the troubleshooting I have
done and he said my approach on Changing the Battery, Neutral Safety Switch and Starter Relay makes
sense and agreed it does fit a starter failure, but they can’t do anything without a hard failure. He felt
bad I have spent a lot of money resolving a problem on a new truck.
He said they would wave the diagnostic fee or help me with a reduced cost for the starter replacement, my choice. There isn’t any value running the diagnostics a third time without a hard failure so I am going to have them change out the starter to fully resolve this item and make the truck reliable again. I have ruled out all the non hardware items and will have replaced all the potential mechanical items at my expense. I am glad the dealer is helping me and very disappointed in Toyotas position. Your solution was to run a diagnostic a 3rd time that showed nothing so far.
As feedback, if you would add a technical review in cases with this much troubleshooting data, I would think you would have come to a different outcome
I will have the dealer replace to starter completing the worst case change out costing me just under $1K total for everything to get it back to being a relaible truck with no help from Toyota. This is just to complete my documentation. Unless of course it fails again
