Backpacker Dan
2026 Toyota Tacoma DCLB ORP
I got mine for a STEAL! $200 total from a local guy who took them off for a custom build that is being raffled off. I got it off this build..
here is the install guide for the rails. It says to not torque
You should DEFINITLY torque the bolts.
Step 3 on page 4:
Torque All Bolts to 40Nm (29.5 ft-lbs)
Sequence 1 - 5, Bottom, then Top (each bracket)
LS13
2025 Taco
Got mine installed and torqued to correct specs. Not to mention that these rock sliders are made in Canada !
15DarkSide
Shayne
Anyone have a link or part number for the OEM bolts for these. Found some used, but bolts aren’t included.
Ruckus
2025 Tacoma SR5 4x4
Every Tacoma should have these bolts already installed regardless if you have side steps installed. Get under your truck with the slider and remove the bolts that align with the mounting holes and reuse them to mount the sliders.
rybern
Ryan
Albertville, AL
'25 TRD OR, 00 Taco 4wd, '21 Corolla XSE
Yep, my 2025 has the bolts installed.
