Oil bolt and pan
Miqie
2024 TRD Sport-Bronze oxide.
I'm changing the oil on my Sport. When I removed the oil bolt the area around the threads is raised, almost like the washer is glued to the oil pan. I hit it a few times with a screwdriver and it wouldn't budge. So my question........is the area around the oil pan threads supposed to be raised or is it smooth? As I said, I don't know if the washer is stuck to the pan, or there is supposed to be a raised area and they just didn't put a washer on at the factory, because there was none with the bolt when I removed it.
Sandeep1994
Sidhu
Yes thats the washer and u need to take it off I had a same experience for first 2 oil changes but then at 3rd oil change i hit the washer really hard and it came off . Try again and hit hard it will come off .
Darrin Carter
Buckshot
SAULT STE MARIE
2024 tacoma TRD sport premium
Yes I had the same experience on the 2 oil changes I did. Just be careful not to scratch the surface under the washer. I have the same issue with my sons 3rd gen
Miqie
Miqie
Thank you Sandeep and Darren. That eases my mind. Didn't want to bang on it too hard and find out I'm hitting part of the oil pan itself.
