Oil Drain Plug Torque Value?
RaoulDuke
Gabe
Hawaii
2026 Tacoma TRD Pro & 2025 4 Runner Limited
Could anyone tell me or point me to where I could find the torque value for the oil drain plug? My TRD Pro just hit 1000 miles and I'm getting ready to do an oil change.
ColoradoBoo
Rick
Monument, Colorado
2026 Toyota Tacoma Limited Hybrid
As you work more on vehicles, you’ll get a feel for the torques. A good practice is to put on the drain plug at 30 ft/lbs and notice how it feels. Then remove it and replace with that same feel then put the torque on and see what it’s at. Most likely it will be lower. I never torque oil drain bolts but, sometimes, I’ll unscrew them to see if they were snug enough…if not, I’ll give them a bit more “mmph” when tightening.
Things I double-check with my electronic torque are spark plugs, all engine parts (alternator bolts, etc) and wheel lug nuts.
Porwal22
RI
‘25 TRD O/R
An aftermarket company needs to make a metal lower oil pan for these engines. A plastic oil pan is just an engineered failure waiting to happen.
Pappy
Jon
Intermountain West
Uh? I could have sworn mine is steel. So, I went out with a magnet to check. Sure'nuf, it's steel.
Porwal22
RI
‘25 TRD O/R
Mine is plastic. I wonder if they have plastic pans on the regular engines, and metal ones on the hybrid (max) engines? Now I have to do some research!
Pappy
Jon
Intermountain West
I have non hybrid.
Porwal22
RI
‘25 TRD O/R
Pappy, I am an idiot, I definitely, definitely, need better eyes….
That damn thing feels like cheap plastic. I just checked on the Toyota parts website. Model years 2024 to 2026 hybrid and regular take the same lower oil pan (part # 12102-F0050).
Mercedes
≈39N
2026 TRD Sport "Mercedes"
The engine oil drain plug, I've never torqued. I tighten as snug as I can with one hand, using a box-end wrench. I might then hit the end of that wrench with a slight bump. Then stop.
Installed my Fumoto drain valve like this during the last oil change. It's still sitting there nice and snug.
I've never had a drain plug loosen up on me.
For oil filters, I follow the manufacturer's instructions on the package. It's typically lubricate the o-ring and tighten to 3/4 to one turn. 99% of the time, 3/4 of a turn is also about what I can do by one hand.
For other maintenance procedures, I will use the specified torque values. This includes other drain plugs, which might involve a metal crush washer.
