saerandy
Randy
Virginia
2024 SR5
Based on the Oil Geek's UOA on his SR5's diff oil changed at 5000mi I decided to do it earlier than the 30,000mi I was planning. I really don't have any regrets at all. As you can see from the photos, there was some metal in there that was probably from manufacturing that was caught by the magnet doing it's job. However, when pouring the used oil out, you can see that it is absolutely saturated with glitter. This is typical for break-in but TOG shows a stat that 82% of part wear is due to particulate contamination, so I'm glad to have done it when I did. If I could do it all over again I would've done it at 5000 miles and then again at 30,000 miles. As with everything, your mileage may vary and you do what you want, but I thought some might be interested in seeing what's going on in there especially if they were possibly gonna skip/delay the 30,000 mile differential oil change. Don't forget there's one in the front too.
2024 Tacoma Pics of Diff Fluid Changed at 24K Miles. Sorry I waited... oil full of particulates 4CD6AE7C-D553-428C-9E04-E36C6F3AA577_1_105_c
2024 Tacoma Pics of Diff Fluid Changed at 24K Miles. Sorry I waited... oil full of particulates 962AA651-4D7D-4C22-9D3D-9BF7F888E044_1_105_c
2024 Tacoma Pics of Diff Fluid Changed at 24K Miles. Sorry I waited... oil full of particulates 707DEA15-BF74-49B7-9A2A-2DE2F97DCB2A_1_105_c
2024 Tacoma Pics of Diff Fluid Changed at 24K Miles. Sorry I waited... oil full of particulates D7AA6083-6031-4AAF-9967-97D41928B1FC_1_105_c
2024 Tacoma Pics of Diff Fluid Changed at 24K Miles. Sorry I waited... oil full of particulates 0DC0E64B-2B34-4063-97BA-41CCF41E7DDE_1_105_c
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Thanks for the info
Last vehicle I did at 1500 miles, I was amazed at particulates at bottom of pumpkin, on the magnet and in the fluid. I did it again to see if the break in had settle down at 2500 miles and it had not. I think I'm gonna do first one on the Tacoma at 2500 miles.
Had to go check, no cover on the diff to remove. So pretty simple change for sure.
saerandy
Randy
Virginia
2024 SR5
I did a drain and fill. Just to get it done today since I had time I used the Valvoline Advanced Full Syn which is a 75W-90 vs 85 (it’s on sale at NAPA for $40 for a gallon). I’m planning to let that circulate a bit for the next 5 to 6000 miles and then at the 30,000 mile mark change it again. Will likely use the correct viscosity since I have some time to get it ordered at a reasonable price between now and then.
glk21c
MD
2007 Tacoma
Hi, you should look at the rear differential again. I'm pretty sure there is no cover to remove. If I am wrong, my apologies.
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Yep you are correct, I was getting ready to check if the gasket was re usable. That make's it easier I suppose
Delta1Seven
I am about to hit 10k.
Did you do both front and rear or just the rear?
LincolnSixAlpha
Brian
Phoenix
Did all diffs, transfer case, and 4 quarts of transmission fluid @ 30k. There will be filings/shavings as the gears mesh together to bond. All normal. Will repeat @ 60k.
@Delta1Seven Depends on how you use your truck. If your towing, heavy Offroad, then I'd say sooner rather than later, 15K would be satisfactory.
I dont tow, or offroad, so pretty easy to extend the changes out a bit.
