rear brake job, fully extended cylinder
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
I'm in the middle of doing a rear brake job, and while the truck was in EPB Service Mode, it came out of that mode (I think I sat on the key fob or something) and now I have a rear brake cylinder fully extended and the truck is throwing emergency brake warnings, and I can't get it back into EPB Service Mode to recompress the cylinder.
How do I get that cylinder recompressed? Do I need to loosen the banjo valve and bleed it a little bit, or is there a way to get the truck to pull it back in?
What was your procedure to put it in to Service Mode?
hogshooter
hogshooter
Corey
Plant City, FL
with door clsoed, power button twice, hold down brake pedal, brake switch up 3 times, down 3 times and hold down on the last down for 10 seconds
Interesting, seems to be the correct method. However in order to release it when you're done you just hold the brake switch up (to engage it). Not sure how that could have engaged like you say.
24tacoman
2024 TRD OR 6M
Use a scan tool to put it back into service mode. You could also keep trying the EPB Service Mode procedure, it is really finicky and it took me 10 tries to time it just right. Do not try to compress the rear brake cylinder straight back in, there are cases of folks damaging the EPB actuator doing this while it is not in service mode
CyberTaco
Anthony
Grand Bay, AL
2025 Tacoma TRD Off Road Dual Cab, 2020 Subaru Outback Premium
What is the preferred scan tool to use?
shuo
shu
Seattle
2026 TRD Off-road Bronze Oxide
I think you can manually retract the cylinder by removing the epb module and using a hex socket. There’s YT vids on it
JayTech
Jay
2025 Toyota Tacoma TRD ORP
Remove the 2 screws that hold the actuator onto the caliper and separate them. Push the piston all the way back in and install onto vehicle. Next take the actuator and unplug it. You can either turn it back by hand or some people have had success by using a small battery and some wire. The safer method is definitely turning it by hand. Once you turn it in, just reinstall onto caliper, plug it in, and then pump brakes. Once that is done, either try to put it back into service mode and then take it out so it properly sets the position or operate parking brake on and off a few times to make sure it is working(This has worked for me before). If parking brake light is flashing or giving you an error you may need a scan tool to clear the fault or try disconnecting the battery to let that clear the codes.
