- First Name
- Dane
- Joined
- Sep 16, 2024
- Threads
- 1
- Messages
- 25
- Reaction score
- 23
- Location
- Muskegon, MI
- Vehicle(s)
- 2024 Tacoma SR5
Re: factory welds (full encirclement)
My grandmother used to weld exactly like this. We had to take her welder away and put her in a home.I'm not a welder, so I don't want to hear anything about it. The collars are basic, but get the job done. Highly recommended for the price.![]()
Your grandma was a badass and deserves to spend your inheritance on proper care.My grandmother used to weld exactly like this. We had to take her welder away and put her in a home.
Bump ! No Comments - I thought the design of the anti crush attachment bolts would generate some discussion/feedback ..???Hi All, I ran across this on eBay. I'll copy the jist of it here in case the item gets removed from eBay. Looks like a single rear point with spacers for those trucks missing the frame supports/collars ... Comments ???
Red Carbon Steel Rear Tow Hook Mounting Shackle Bracket For Toyota Tacoma 2024+
a-car-toy
(253)
95.9% positive
Seller's other itemsSeller's other items
Contact seller
US $89.99/ea
The holes you bolt through are the same size the larger hold between them isn't used (also shown in the pictures I provided previously)thank you for your reply. I did check those out, however, the holes on the frame are two different sizes. Can you please explain how you managed to fill the empty space? Thank you
Would you happen to know if welding them onto the frame will void the warranty?I feel we are clear. Are you?
No clueWould you happen to know if welding them onto the frame will void the warranty?
Did you have to shave down the inside of the Cornfed collars? The ARB bolts don’t fit.I'm not a welder, so I don't want to hear anything about it. The collars are basic, but get the job done. Highly recommended for the price.![]()
