soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Early on there were some issues with the mounting hole pattern being different on different trims. Anyone know if that has been resolved?
dvrgz
Los Angeles
you’re right. I totally forgot. I guess I’ll report back when mine get in. I have an sr5.
here’s the picture from @TheGreatWhiteNorth …
2024 Tacoma Rough Country Wheel Well Liners installed IMG_8016
Sancheesy
Shawn
Ontario
jsuber
juke
Jls297#40601
I installed those but easy is not the term I would use. That Toyota bracket that connects the bed to the wheel well body was a MFer. Those screws were delicate without the wheel well liner. Glad yours was easy. I didn’t remove my tires.
4GTD
Detroit, MI
2024 Tacoma TRD Off Road
@StreeTaco how flexible are the ARK mud flaps? Curious to see if they can withstand being pushed back with trail objects (rocks, ice, mud, etc.)
StreeTaco
StreeTaco
TN
2024 Tacoma TrailHunter
Hard to explain exactly how they feel.. they are rigid but flexible.. to a point. I think they would crease if bent over 90 degrees to itself.
StreeTaco
StreeTaco
TN
so the roughy country wheel well covers dont sit quite right on the sr5 (with no fender flares). I’ll live with it though.
The ARK splash guards fit perfect. Excellent quality.
The rears aren’t installed correctly. They should tuck behind the metal fender lip.
Does this go on top of the OEM plastic liner?
dvrgz
Los Angeles
Are you sure? I don’t have fenders. I don’t see how it would’ve fit otherwise. I can check though. It was bitch to install.
Sent you a DM. Thank you StreeTaco @StreeTaco
