Small RPM bounce while cruising.
Keithz24
Georgia
2024 Tacoma Off-Road
So, I have started to notice that while driving at around 45mph, and at or a little above 1500rpm, there is a noticeable surge feeling/hesitation, and the rpm hand bounces up and down a bit. I'll try and get a video and post it here. Its more prevalent while going up a hill. Just wanted to make a post to see if anyone else has experienced this.
4g hybrid
Ever driven stick shift?
If so, would you describe it as a mild lugging sensation? Or different?
CAMTuning
Cameron
New Mexico
2025 Tacoma TRD OffRoad
Hybrid or not? I have seen this on some hybrids
Compy386
Oklahoma, USA
2024 non-hybrid here. I've noticed this with mine a handful of times.... Only during some really low speed cruising down neighborhood streets and such.... I typically just give it a little more throttle if I'm able and it goes away. I'm just chalking it up to computer/OEM tune weirdness.... don't even really care too much anymore.
My late-model motorcycle acts similarly at really low speed cruising, so I believe it's just a symptom of modern emissions programming, even though it sucks and is annoying.
Keithz24
Georgia
If so, would you describe it as a Mike lugging sensation? Or different?
My 3rd gen was a stick. I would describe it as the trans is slipping or an engine misfire. Like it's trying to shift but doesn't know if it needs to or not. No CEL though. I wonder if it could be the torque converter?
Keithz24
Georgia
My truck falls under the TSB for the transmission. Any chance yours does as well? I had noticed the issue a few times when I first got the truck new but figured the transmission was just learning. I got 22k on it now and it does it often on my way to work and back home.
4g hybrid
Pay attention and share back exactly what combination of mph/kph + rpm appears to trigger it. Also what octane fuel your using.
Keithz24
Georgia
I will try and get a video of the event. I mainly run 93.
Keithz24
Georgia
Here is a short video of what I'm experiencing. You can skip to around the 40s mark to see what I'm talking about.
4g hybrid
If you run 89 octane or 87 octane, see if the intensity and mpg range changes (rpm range will be the same)
Compy386
Oklahoma, USA
No... mine doesn't fall into the TSB, thankfully. No issues otherwise and this RPM bounce seems to rarely occur and always goes away with just the tiniest bit more throttle, which leads me to think that it's just weirdness from the computer/stock tuning. Mine has been on 91 octane non-ethanol fuel since it was new.
Like I said, I've got a late model bike that does almost the exact same thing at really low speed cruising and I know for a fact with that engine that it is due to excessively lean stock tuning. I would not be surprised at all if it's something similar going on with these trucks since they're trying to squeeze every MPG possible from this engine.
I just drive with a heavier foot and it seems to like it. :wink:
ThatEngin3rd
Houston
2025 SR5
My initial thought is the Torque Converter. Same thing is happening to my Ford Explorer work vehicle. I was initially thinking that was a transmission issue, but I also have the issue in my work vehicle if I have to slam on the brakes, it goes into a lower gear and stays there as I get back on the throttle. Nothing like going 60-70, slam on the brakes, and get back on the gas to find it in 3rd or 2nd gear and max revving.
Keithz24
Georgia
Took it to the dealer and that is what they diagnosed (bad torque converter). Trans and torque converter are on order.
