Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter
Pappy
Jon
Intermountain West
Phone can only connect to one WIFI point. If you want to use it with Starlink and Android Auto or Carplay you need to use a USB cable to the display head.
Which is what I always do.
TacoFish
Bill
Snoqualmie, WA
2024 Trailhunter LB, 2023 Audi Q4 etron, 2025 Subaru Outback Wilderness
I have had my Starlink mini mounted to my roof rack using the the Veritas Vans mount and rack mount kit. I run the power and ethernet cable through the back window and cover that with XFasten Transparent Window Weather Sealing Tape. I plug the power into the Cig Adapter or USB-C. I plug the ethernet cable via USB-C adapter into my iPhone. Then it can be connected to the vehicle via WiFi. I have been looking for a black or gray cover that would fit over the Veritas Vans mount given it does not really blend in with black roof rack and canopy (white on black/bronze oxide). I think I will get this adapter and get the black liquid silicon case. 122 degrees F is the redline on temp for the Starlink mini. I would probably remove and stash it when I am not in the vehicle. That looks much easier with the adapter vs the roof rack mount.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Got my Broken Rover 3D printed mount. Quality is so-so but design and function is good.
I spent some time shaving the rough edges and reinstalling on the Mini a few times. My tiny brain finally realized my copy will only lock into the JBL dock if I press it in without it being mounted on the Mini first. Once the mount is in the dock, then it’s easy to slide the Starlink into place and lock in.
Fortunately, the mounted Mini fits my dashboard and is over top of my existing bullet point mounts, so it is not too busy and there is no interference.
I had bought a silicone sleeve, but returned it because it’s too thick and butts up against the windshield, in a way that interferes with the installation of the plane mini. I have ordered a ranger wrap to put on. Another problem with the silicone sleeve is that it was too reflective despite what the seller on Amazon claimed.. once I get the Ranger wrap on, I will post pics.
TacoFish
Bill
Snoqualmie, WA
I have on order, should be here next week. Great feedback on the silicone sleeve. I was about to order that as well, now I will not. I look forward to your feedback on the ranger wrap.
