Still having a hard time parking my long bed :(
ohhkk
Sacramento
Honda Civic
Embarassed to say this but I’m still struggling parking the long bed. I try to back in to spots and 99% of the time I can’t do it and spend a minute correcting it. Does anyone have tips or maybe a good video on this?
ambit
philly
Long bed turning radius is about 2' more than the short bed :(
Rmarin4272
Ryan
Pull forward more than you think you should before cutting the wheel and angling truck as much as you can. Use your backup camera and just make sure you don’t clip the car on the short side and you should be fine!
FossilHunter
So glad I got the premium package, the 360 cameras help a lot.
But short of buying an aftermarket camera package a trick I learned in driving school was to learn a specific point on your vehicle to line up before making your turns. We used it for parallel parking but the principle should apply. Find a spot on an empty lot you want to park in and give it your best guess as to where you want to start. Then see how much you were off by and adjust from there. Not every lot has the same dimensions but once you have a baseline of "from x feet away line up the edge of the spot with x point on the vehicle before starting" you should be able to make mental adjustments for other spaces.
Also no shame in making multi point turns in some of these tiny lots, many are designed for compact cars and not our long trucks. Half the lots don't even have spots long enough for the long bed where I live, gotta hang out a bit on either end.
BTAO
Andy
NE
2025 Trailhunter
#1 is learn to use your mirrors. The cameras are nice and all, but mirrors are where it's at. It's all semi's need to back up, and is all you need. I like the cameras if I'm trying to miss an object, but practice with your mirrors. Remember you can cut it all the way when you reach your rear wheels. You can get close to the car next to you on the inside using the mirror then cut it in a tight lot. Bigger trucks, gotta get closer to do it in one shot. And, if your mirrors don't let you see what you need, you need to adjust your mirrors.
trailhunger
2024 TH
the camera tech helps a lot, but yes the LB drives big, it is after all as long as many full size pickups, just narrower. My old Dodge Ram is impossible to park, horrible turn radius. I guess my only advice is drive a really long shitty old truck and you'll ace parking a gen 4 LB taco.
