California TRD Pro Suspension - South Lake Tahoe
lfe
South Lake Tahoe, CA
2024 TRD PRO
$2200
Pulled from my 2024 TRD Pro at 12k miles.
Included are the front upper control arms, front struts, rear shocks, rear springs, Westcott Designs preload collar lift kit, oem front strut collars, and all hardware. Everything you need to run 35s.
Rear lower shock mounts have a few scrapes - purely cosmetic.
I can install for $500.
Willing to ship if you provide a shipping label (or labels - probably best to split some things up into smaller boxes). No, I won't get you a shipping quote. It's going to be several hundred dollars at least.
tkrum015
Ted
Olympia
Good deal for someone . What did you replace this with?
lfe
lfe
2024 TRD PRO
I have the same Fox coils going. What UCA's did AccuTune recommend/sell you?
They strongly recommended a tubular option rather than billet for the sake of strut clearance. I went with the icon delta joint since I live in an area with snow at least 4-5 months out of the year - corroded hiems are a lot of extra maintenance.
tragisj
Alaska
Toyota Tacoma 24 OR, Toyota 4Runner 21 OR
Did you add preload? I was looking at those same Pro UCA's but was getting the impression 2+ inches of lift is too much for them. Nice truck BTW. Nice tip on snow too. We are in winter now already
lfe
lfe
2024 TRD PRO
Main reason I ended up with these (aside from weight and needing to adjust the shocks around it - I'm at close to 6800 pounds fully loaded) was the full aluminum body. Didn't expect a steel body shock to last long doing several months in snow every year).
Add preload to the new foxes? I didn't - but Accutune installed a stiffer spring and set the preload. They worked their magic and I didnt have to touch preload and kept my front ride height the exact same.
tragisj
Alaska
That is Beast Mode weight. AccuTune is the great resource.
lfe
lfe
2024 TRD PRO
Adds up quick - blew my goal by a few hundred pounds, but ya, at least accutune got me set up proper. Now just waiting on a solution for my brakes....
