Under seat HVAC deflector
cmillls45
minnesota
tacoma
Has anyone come up with a solution to the under seat deflectors to angle them up about 30-45 degrees? I don’t know if all floor liners are similar but my huskys somewhat block the rear seat vents. Maybe someone’s 3D printed something you can stick on? I know eBay has some but those aren’t angled up and are more towards keeping garbage/debris out of the vent.
2024 Tacoma Under seat HVAC deflector IMG_0046
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Wonder if the Husky liner can be softened gently enough with a heat gun to allow you to flatten the lip.
TX-BluStreak
Tom
Houston
25' TRD Pro - Underground
Idk if this helps, but you can buy an under-seat vent cover on Amazon for $10. Then you can use @lauren01 suggestion to heat gun the husky mat and reposition it under the vents, so it doesn't obstruct airflow.
2024 Tacoma Under seat HVAC deflector ScreenHunter 187
cmillls45
cmillls45
minnesota
tacoma
Someone on TW suggested putting shims under the vent, this worked! Thought I’d share for the next one who encounters this.
TX-BluStreak
Tom
Houston
There is a product for this as well
https://a.co/d/0gifXGQF
It's a good idea, and I guess I'm the idiot because I fell for it. The description clearly says it's compatible with 2024+ Tacoma models, but that's a complete and utter lie (false advertising, if you ask me) because it definitely didn't fit in my 25' TRD Pro. It's a tad bit short.
I don't even know why I bothered buying one in the first place, considering I don't even have anyone sitting in my back seats anyways. :facepalm: I'll just blame this one on impulse buying. But be warned, it's not worth the trouble.
