USB ports in bed
CBarclay
NC
TRD OR
Hello everyone, I have a backcountry trip coming up and just realized my USB ports in the bed are not working. I've checked the 7.5 amp fuse and it's ok. With the truck on I've checked the ports using a working and good cable and have used an air duster to clean the ports. What else should I look at to get these to work?
Thanks!
Miqie
2024 TRD Sport-Bronze oxide.
On a related note, what type of fuse is it? It blew on me several months ago. I took it out meaning to replace it, never did, and now it's lost.
Devleen [SCAMMER]
Banned
Banned
Dev
Thanks!
Check if the 120V AC inverter switch on your dashboard (or the bed panel) is turned on to activate power. Inspect the plug connectors behind the bed panel and test with a multimeter to verify voltage (12V). If power reaches the port but your device won't charge, the internal pins might be unseated.
Rmarin4272
Ryan
Arizona
Thanks!
Change the fuse anyway. Cheap what if fix if it works
CBarclay
CBarclay
NC
TRD OR
You were absolutely right. The fuse looked intact but once I tested it with my meter I found it was bad. I tried both a regular 7.5a and mini fuse and both worked. The little rubber cover doesn't work with either of those though. The fuse I removed looked different than ay other fuse I've seen. See pic. I'm used to the fuses having longer 'legs' and the ones I tried seem to be fine and all works ok now. Thanks for the help!
2024 Tacoma USB ports in bed IMG_0515
2024 Tacoma USB ports in bed IMG_0514
Rmarin4272
Ryan
Arizona
I had to walk into autozone and look at all the options to find it. But if you look up what fuses Toyota uses you can then just order some online. I forget what they are called but it’s easily found. Glad it worked out and it saved a bigger headache
