Which Shock/Suspension upgrade should I get?
zAustin
CO
2025 Toyota Tacoma TRD Off-Road
I have a 2025 Tacoma TRD Off-Road and am interested in a suspension/shock system upgrade that lifts my truck between 2 and 3 inches. My vehicle is a daily driver on pavement, but I want the capability for occasional overlanding and off-roading. My main goals and requirements are:
- Maintain daily driving comfort while gaining off-road capability
- Clear at least 35" tires
- Keep the total cost under $4,000 for both the lift and UCAs
I've asked many people and seen many videos describing King Shocks as the "Holy Grail" of suspension upgrades. Even though I have considered buying these shocks, it occurred to me that I don't go off-roading at every given chance I have, and especially not any crazy rock crawling. So I'm not sure if I should invest in King Shocks since I probably won't use them to their full capability. Not to mention, buying a kit of King Shocks with upper control arms tends to go over my $4,000 budget. So after more research, I found a Dirt King kit with both front and rear suspension, along with upper control arms, all for just under $3000 called the MT Trail Runner Kit. Dirt King UCA's have been mentioned to me as a good option, but I've never heard anything about their actual springs and lift kits. So my main questions are: Is the Trail Runner Kit the best option for my setup and budget? Is it completely worth getting an entire kit, or should I just invest in front suspension? And finally, are adjustable shocks something I should consider because I won't always have heavy equipment on/in my bed? Or do you guys have any other recommendations?
Rmarin4272
Ryan
Arizona
Hey man! Congrats on starting the journey of suspension upgrades. I know one person that has had a nightmare of a time with DK. I have the OME MT64 setup that has had its hiccups. Overall performing amazingly. From all I’ve seen the bilstein 6112/6100 are pretty bullet proof.
That’s my 2 cents
Do you own install! Learn a ton and enjoy it
Toyotimothy
Timothy
Selmer, TN
I recently put Bilstein 6112/6100 on my truck. Had them set for 2.25” lift in front and went with an icon 51215 spring in the rear. Currently sitting at 24” from center of wheel hub to bottom of fender flares up front and 25” in the rear. I might’ve went with the wrong springs but you can choose your own. I’m running 35x12.5x17 Toyo open country rt trails on method 305s with a +25 offset. You’ll probably need a dr kdss track bar correction kit for the rear. I actually have my old one (for 4th gen)listed somewhere on here if you’re interested. Make an offer. It’s in good shape. The Bilsteins are similar to stock ride but to me they seem to absorb the bumps better. I learned the hard way that I should be running C load tires. I previously had E load. There’s a huge difference in ride quality. Just keep that in mind when you’re picking your tires out. I went with the Bilstein because it’s a set and forget system plus I didn’t want to deal with any teething issues that others mentioned about
2024 Tacoma Which Shock/Suspension upgrade should I get? IMG_8258
other companies. Not that Bilsteins are better. I just wanted something that I didn’t have to worry about. Plus as everyone says it is quite the bang for your buck. Bilstein is also what came on the truck so I figured if Toyota trusts it, then I could. Included a picture so you could see what it looks like. Best of luck. Hope this helps.
VB Taco
Virginia Beach, Virginia
Have you considered the OEM lift kit? 3" in front, 2" in the back for a 2.6" lift over all. UCA included for $2000 ball park.
tkrum015
Ted
Olympia
I have the TRD lift on my 0ff road . It drives and handle much better than stock . I am only running 285/70 17 and do go out on forest road mountain biking.
2024 Tacoma Which Shock/Suspension upgrade should I get? IMG_9672
zAustin
CO
That’s my 2 cents
What have the hiccups been?
zAustin
CO
How much did this all cost roughly? Also what UCA's are you using?
zAustin
CO
Which company/website did you buy from?
zAustin
CO
Does it come with UCA replacements? Is the suspension a big noticeable difference from the stock Bilsteins for small bumps or potholes as well?
Rmarin4272
Ryan
Arizona
The integrated top hat assembly can have some play. It’s 100% safe but can make noise that drove me nuts.
I ended up doing the whole OME lineup with UCAs and rear springs. Settled on the medium springs (440+ lbs). Also installed extended rear sway bar end links from Dobinsons as well as the TRD lower knuckles and TRD tie rod ends. AND have to upgrade your bumps if you lift so went with Timbren OBSTORTNDR bumps.
All that totaled $3900. Self install saved money but probably spent $500 on tools.
As for the hiccups in detail. It all started after off-roading and the knocking noise was evident when turning right, when going between 5-30mph. Took several videos of the issue and sent to ARB. They agreed it was a warranty issue and sent me out modified units that eliminate the play. Not sure if they are implementing a fix for all because another customer I’ve spoken to has been told something to the effect that Australia doesn’t think it’s a big enough issue to mandate a change.
Luckily I could do the re-install myself and the alignment shop didn’t charge me to do another alignment.
I’ve spoken to another person here who went through 3 sets of front dirt kings that all failed before he got his $$ back for the fronts and rears (kept the UCAs) and did the Fox TRD lift.
VB Taco
OEM so any dealership that has online sales. I'm waiting for hopefully 🙏 a spring 25% off deal like last year. Should have done it while the getting was good.
tkrum015
Ted
Olympia
Yes. All the parts needed including the lower knuckle pivot. Yes it rides much better than the stock recalled OR bilsteins.
Toyotimothy
Timothy
Selmer, TN
$1659.98 for the Bilsteins, $599.95 for elevate chromoly upper control arms and $299.64 for rear springs. I installed it myself. That’s a story in itself. Got an alignment. Swapped tires to a c load. Also added the Toyota lift kit extended tie rods and steering knuckles on the lower control arms. Can’t remember how much they were. Probably under $200 or a little over.
I have a set of JRI 6 way adjustable shocks on my OffRoad. You can get a full set with UCA’s for about $35-3600. My budget was 3K and did not get UCA’s. My tires 33’s are wearing normal and the stocks UCA’s don’t touch the shock at full drop, very close about 1/4 inch! But with 35’s you may see some uneven wear without UCA’s? Put them on 2 years ago. I have 40K miles on them now and they still perform like new. The adjustability is the ticket! Setting 1 and it rides pillow soft, setting 6 and it rides super firm unloaded, almost sport car firm. When I’m towing or loaded down I can adjust accordingly for the load. Setting 3 is a similar firmness to stock TRD shocks. I was also looking at Kings but the problem there is you typically need them rebuilt every 30-40K miles. I spoke to JRI they assured me these were thoroughly tested and would last far longer than Kings and are rebuildable. In addition many premium shock seals fail where I live during the brutal cold winter. These were tested to -40 and have proven reliable through 2 Montana winters!
https://www.tacoma4g.com/forum/threads/jri-6-stage-adjustable-shocks.8196/
