I'm worried about the bronze rims & my mall cred in 10 years. Not so much the turbo.I'm worried about this new turbo, what do you think?
I think you are in the minority here, look at the pole.I'm worried about this new turbo, what do you think?
That would be for the diesel engines so not that comparable.Toyota have hilux turbo in rest of the world . which is very reliable …
So what in your mind makes a turbo on a diesel different than a turbo on a gas engine?That would be for the diesel engines so not that comparable.
So I used to work in designing mounting exhaust systems for diesel engines and I don't think that's true. Gas exhaust temps are in the 400-500F range, with a modern diesel aftertreatment exhaust gas temps are similar.The larger compression ratio for diesel engines causes temps to be lower than a gas engine, sometimes as much as 200 degrees lower on exhaust temps
