xipoqix_official
Jackie
China
We recently went through the process of adding bed scene lights to a base-model Tacoma that didn’t come with factory ones. I wanted to share a quick breakdown of how the install went.
I’ve put together a few photos and basic steps below in case anyone is working on a similar project. Hope this helps!
First, pop off the bed rail cap. Use a rotary tool (like a Dremel) with a cutting wheel, and carefully cut out the openings along the factory-molded guide lines.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (11)
Next, insert the scene lights into the cutouts you just made, and secure them using the factory mounting holes on the back.
Moving on to the wiring. Remove the factory side light and unplug it. Then, use the splitter harness to connect the factory plug, the side light, and the new scene lights.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (1)
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (7)
To keep things looking clean, route the wire under the bed rail cap and secure it in the clips.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (8)
Finally, snap the bed rail cap back into place to complete the installation.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (9)
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 installation (10)
ejosesa
Joses
los angeles
tacoma off road 4x4
Interesting. I just replaced the caps entirely with the lighted version.
How much did it cost for just the lights and wire harnesses?
xipoqix_official
xipoqix_official
Jackie
China
It should also be worth noting that this title and thread only applies to the mentioned 3rd party lights (or any lights that cut out the caps).
Adding OE Bed Scene lights is a different process.
TX-MD
marvin
AR
Tacoma, 4Runner
Anyone have these already? I’m curious about any water intrusion under the rail cap and onto the underlying body panel - any more than the stock un-cut bed rail
Cabby30
CA
2024 DCLB TRD OR
Based on this image it doesn't look like there is any sealing involved, from the factory or this installation. I ordered these so I'll know more once I attempt the install when they arrive.
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 1787186866940-lh
dante116
Don
Sacramento, CA
Looking forward to seeing how they turn out. I'm hoping you'll be able to do a little better job on the trimming than the install video shows.
Gaming
Gaming
2025 Tacoma SR5
If you make them available in Canada and make a smoked lens version, I would happily buy them and make an install/review video.
There is no seal for the bed caps and any water that gets in drains out the bottom of the bed sides.
Those look nice and let us know how your install goes.
Kjc
Anc
2024 Tacoma OR
I just ordered these too... Didn't wanna spend the $400 plus for the oem set... Any tips for cutting these out... The video showed a cutting wheel... Anyone try something else... Also of anyone finished the install pictures would be awesome....
Cabby30
CA
2024 DCLB TRD OR
My process:
1. Cut out the bulk material with a Dremel and die grinder bit;
2. Then I used a fine file to remove remaining material and try to straighten out and smooth the cuts.
3. Used a lighter to heat the material to smooth it out; applied the flame and then just used my finger to get any extra material smoothed/removed.
4. Mounted everything to the truck and checked function.
5. Protected the truck paint with painters tape and applied black RTV to caulk the seams. Used isopropyl wipes to remove excess RTV and clean the trim and light. (This was very messy)
My main advice is to go slow and not over cut. The first light took me 1.5 hours as I worked out my process. The 2nd took less than 30mins. I have only done one side so far)
Light output is good; especially for the price. I havent seen the OEM ones so I cannot compare. I'll upload a night shot later.
I did like that the kit came with the harness and everything else was plug and play. I would recommend it. Maybe the only other thing I would do is add even a little bit of extra RTV where the connector wires comes out of the light, just in case.
Before RTV:
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 IMG_7725
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 IMG_7727
After RTV cured:
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 IMG_7758
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 IMG_7967
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 IMG_7759
2024 Tacoma How to Add Bed Scene Lights to a Base-Model Tacoma SR5 IMG_7966
Kjc
Anc
2024 Tacoma OR
My process:
Before RTV:
After RTV cured:
Looks good I'm doing mine today since my rails are already warped and lifting in the front... What kind of silicon did you use? Are all the lights still working? I was a little nervous ordering Amazon lights for my truck
Cabby30
CA
2024 DCLB TRD OR
I used black RTV (permatex ultra black).
Lights work great. The only problem is the passenger-side is more warped then the driver side so it’s lifted higher. Try to find some PSA (double sided tape) to help it stick to the bed rail by the cabin. You’ll see where the stock PSA is.
Kjc
Anc
2024 Tacoma OR
Thanks for the response... These are harder to cut out than I thought... Hopefully using the rtv will cover some of the gaps I have 😂....
Cabby30
CA
2024 DCLB TRD OR
It should. Definitely use some isopropyl alcohol wipes to smooth out the RTV and clean up the extras around the gap. Post some pics when you’re done.
