- First Name
- Ben
- Joined
- Mar 10, 2024
- Threads
- 52
- Messages
- 564
- Reaction score
- 456
- Location
- El Paso, TX
- Vehicle(s)
- 2024 Tacoma TRD Off-Road Premium
So, I did a thing. Finally got the light bar I've been wanting to complete (for now) my setup. I ordered this light bar from Amazon. I thought about going w/the CaliRaised version but it was a bit too long for my roof rack. Install was mostly straightforward. I am going to be using the dual OEM Square switch from CaliRaised LED but for now I'm using the switch that came w/the light bar. The toughest part of the install was getting through the firewall. I ended up going around the rubber grommet as suggested in a video i saw online. Once I did that, the rest of the install was a breeze. I spliced the wires coming from the light bar with a 16 gauge 3 wire setup so I could run the wire from the light bar, behind the light bar and down the pillar of the driver side. Other than that, the rest was pretty much plug and play once I understood how to wire everything up.
