GGOffroad
Austin
2025 Tacoma
Hi all! Katie here from GG Offroad. We build OEM camera relocation wiring for the 4th Gen Tacoma and 3rd Gen Tundra, and we're glad to be sponsoring here. Quick intro to what we make and why, then this forum is open for fitment questions.
What we make
  • Tailgate backup camera relocation kits — for running a bed rack, cap, topper, tonneau or swing-out
  • DRV + bed view camera relocation kits — for trucks with the digital rearview mirror and bed camera
  • DRV extension cables in several lengths, for caps and campers
  • Brake light wiring tap cables and camera mounts
How they're built
Every kit uses factory connectors on both ends. Nothing is cut, spliced or tapped into the camera circuit. That's deliberate: the camera video pair is shielded, and Toyota's own wire harness repair guidelines state that shielded wiring should not be repaired — after a splice, performance can't be guaranteed. A plug-in relocation keeps the OEM circuit intact, keeps the install reversible, and doesn't leave a splice under the tailgate to corrode.
Ask here
Fitment, install and wiring questions are welcome in this forum and I'll answer them. If it's something we don't make, I'll still tell you what I know about how that circuit is wired. Install guides and a troubleshooting thread are coming next.
Forum discount
Code TACOMAS4G takes 10% off at ggoffroad.com for members here.
— Katie, GG Offroad
TacoBirdinNW
2025 DCLB SR5
I looked at these. Why is the cost so high compared to something like a 4k wolfbox with front dash cam and rear camera ?
GGOffroad
GGOffroad
Austin
2025 Tacoma
That's a fair question.
A Wolfbox is an aftermarket camera and screen. You're buying the whole system, and it works independent of your truck. Our kit doesn't include a camera at all. It's a wiring harness that extends your existing factory camera, so your OEM digital rearview mirror keeps working exactly as designed. Same image, same backup guidelines, same integration with the truck's systems, no error codes, and nothing added to your dash.
On the cost side: these cameras run LVDS, a high speed digital signal that's sensitive to cable construction, shielding, and connector quality in a way analog video isn't. The cable has to hold signal integrity over 23 feet through a truck, which means shielded twisted pair built to automotive temperature spec, plus OEM matched connectors that aren't available off the shelf.
Whether that's worth it really depends on what you want. If you're fine with an aftermarket screen and camera and you don't care about keeping the factory mirror functional, a Wolfbox is a reasonable option and cheaper. If you want your OEM system to work the way it did before the topper went on, that's what we do.
Kodachrome
2005 Tacoma TRD Offroad, 2026 Tacoma Trailhunter
2026 Trailhunter, iForce max, need for removing tailgate and placing on camper.
GGOffroad
GGOffroad
Austin
2025 Tacoma
spenticus
Spencer
Santa Cruz
2024 Tacoma TRD ORP 1998 4 Runner SR5
I have a super pacific on my ‘24 TRD OR 6’ bed. Since I have the camper shell on the back the mirror is useless, but the camera gives that functionality back. When it works it’s awesome, but more often than not the screen flickers. When routing it, I tried to avoid bends and even put extra shielding on it. Not sure if I’m doing something wrong or if I have a bad route? Is there a recommended route for the cable to the camera?
Thanks
GGOffroad
GGOffroad
Austin
2025 Tacoma
Frustrating one, and worth working through systematically since you've already done the obvious things right.
The route we recommend runs from the CHMSL connector along the headliner to the passenger C-pillar, down behind the pillar trim, under the rear seat, out through the factory floor grommet in the cab floor, along the frame rail to the rear of the bed, then up into the Super Pacific. That path keeps the cable protected and away from heat sources.
A few other things worth checking:
Reseat every connector deliberately. This is the most common cause by a wide margin. You need an audible or tactile click on each one, the CHMSL end, where our extension meets the factory short harness, and the camera connection.
Is there a heat pattern? Does it flicker more after the truck has been sitting in the sun, or on hot days specifically? A sealed camper runs well above ambient, and connector housings expand slightly with heat. If the answer is yes, the fix is usually getting the cable and connector out of direct sun and improving ventilation in the camper rather than rerouting.
Any aftermarket electronics on the truck? Dash cam, inverter, hardwire kit, auxiliary lighting controller. These can inject noise that looks exactly like a routing problem. Worth unplugging everything aftermarket and testing.
If it's still flickering, email us at [email protected] and we can get you a new cable out per warranty.
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
2025 TrailHunter I want to relocate the tailgate camera to work around a hitch mounted spare tire and relocate the bed camera/digital rear view cameras to install a cap.
GGOffroad
GGOffroad
Austin
2025 Tacoma
5Tct2BgVc7RN8W!
You need both kits
Toyota Tailgate Back Up Camera Relocation Cable Kit
This covers the backup camera in your tailgate, which the hitch mounted spare will block. Select the Tacoma variant.
Digital Rearview Mirror and Bed View Camera Relocation Kit
This covers the DRV mirror camera and the bed camera, both of which live in the third brake light on the cab roof and get blocked once the cap goes on. Select Tacoma 4th Gen plus your mount choice.
Both work on the 2025 Trailhunter. And do the DRV kit install before the cap goes on if possible. The cable routes through the headliner and down into the bed, and open bed access makes it much easier.
What cap are you putting on? That determines the right mount for the DRV camera. I recommend suction cup if it has a rear window, external or pivot arm if not.
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
I plan to install the Jusn Designs cap.
GGOffroad
GGOffroad
Austin
2025 Tacoma
trailhunger
2024 TH
I have the GG off-road kit from back in Oct ‘24, works great and went creative with my cargo cam - routes that to the roof behind my roof rack spoiler…the only complaint is the in-&-out glitching on the rear view mirror display route: cuts out frequently- not sure if that’s from summer heat or what. It’s distracting and royally sucks ass and I don’t use it that much when I otherwise should be
GGOffroad
GGOffroad
Austin
2025 Tacoma
Yeah, that's annoying and you shouldn't have to live with it. Good news is it's usually fixable.
Heat is very likely the culprit. The cable itself is rated well past anything you'd see, but sometimes heat affects the connectors. It can help to unplug and reseat the connectors.
Second thing to check is the routing for tight bends. Anything tighter than a 3-4 inch radius can go marginal in heat even if it's fine in cooler weather.
Third, anything aftermarket wired near the mirror? Dash cam, inverter, hardwire kit. That stuff can inject noise that looks exactly like a heat problem.
Also worth ruling out the mirror itself. Next time it cuts out, aim the AC at the mirror for a couple minutes. If the picture comes back before the cab has really cooled off, the mirror is running hot on its own and the cable is secondary.
Your cargo cam routing up behind the roof rack spoiler is a solid setup, by the way. Curious how the view turned out.
We can always send a new cable under warranty if needed. Let us know!
trailhunger
2024 TH
I appreciate that and yea I think* its a summer time thing in Colorado / winter it runs fine from what I can tell, case in point the roof cam feed is stable no issues. Will journal on performance as we enter cooler temps this fall…
there is a Toyota dash cam next to the mirror hardware, and it works fine under thermal extremes from what I can tell…I know that if I go to Toyota and claim their mirror apparatus is bunk when exposed to the full sun & a windshield shade deflector they’re gonna deny any claim because of the re-route
GGOffroad
GGOffroad
Austin
2025 Tacoma
One thing worth poking at. You said the Toyota dash cam next to the mirror handles heat fine, and I believe you, but a dash cam can work perfectly while still throwing electrical noise onto a nearby circuit. Different failure modes. You could unplug it on a hot day and see if anything changes. However, I agree it is not super likely. Reach out anytime you want to investigate further. Let us know how the fall logs go.
