MrB4D
Michigan
'24 Trailhunter
I got bored on a 5hr flight and figured I would make the "secret cubby" organizer. The main things I wanted to store are the lug nut key and a spare battery for the key fob (and card fob). I was also able to fit in a Leatherman Sidekick (though I'm sure other small multitools would fit). On the back there is a cut out for 2 command strips to help hold this in place (some velcro strips would work too, though they might need some trimming). I added some moleskin to the inside of the upper Leatherman cutout to help hold it into place and help silence any rattling. I think a slot or 2 for keys would be a good option, but with how easy it is to break into vehicles, I thought it might be better to not include it... STL included so you can add yourself if you think it is an acceptable risk.
NOTE: the point of this organizer is not to be something you use daily, just something you use in a pinch (key fob/headlamp goes dead, wire needs cut, etc)
STL image
2024 Tacoma Secret Cubby Organizer 3D Print DIY (STL included) 1791224046139-wu
Installed Image
2024 Tacoma Secret Cubby Organizer 3D Print DIY (STL included) 1791251982569-bo
(Black plastic doesn't photograph as nice as the grey stuff from the other post, sorry!)
Some notes:
  • Command strips do not stick to the plastic in the cubby very well
  • A layer of moleskin on each side of the Leatherman stops it from shaking (maybe have it wrap around to the front of the organizer to stop fraying and improve longevity)
  • I removed the pocket clip on the Leatherman to help it fit better
  • Getting batteries out is a little challenging, but with command strips (or velcro) pulling out the organizer isn't an issue
Potential modifications:
  • Adding an angle/champers to help guide the multitool in
  • Key slot (at your own risk)
  • Slots for some common socket sizes
  • Socket wrench or screwdriver with different tips
  • Flashlight
  • Air Tag/Pixel Tag (go Android) if you forget your parking spot often
  • CR123 batteries
Enjoy! And if you make some changes take a pic and share!
TexasBlueCrush
Tex
4th gen TRD Sport 6MT before that 3rd/2nd gen TRD Sport 6MT
MrB4D that is absolutely amazing. Now ya got me thinking.....
MrB4D
MrB4D
Michigan
'24 Trailhunter
Thanks. I see this as less useful than the center console organizer from a few weeks back. It can be tricky to get the batteries out without pulling the whole organizer out. I think ergonomics could be improved by using 1 type of battery (AA, AAA, CR123) and installing next to each other with a little more space between them. Dang that ease of use/space trade off.
I hope you're inspired to improve on it or make something else! Tag me if you do!
TexasBlueCrush
Tex
You have and thanks. I spent half the night trying to build on your idea for that round cubbyhole in my 2024 Taco. I'm more of a "prepper" kind of guy and I was thinking of stashing a micro hand crank am/fm emergency radio, a mini Bic lighter, and a couple of other things. Kind of what i keep in my pocket every day. I'm headed to Lowe's later today and see what i can find. You're onto something great. Thanks for sharing.
2024 Tacoma Secret Cubby Organizer 3D Print DIY (STL included) tempImageaB3umt
2024 Tacoma Secret Cubby Organizer 3D Print DIY (STL included) imgres
2024 Tacoma Secret Cubby Organizer 3D Print DIY (STL included) tempImage9irCqy
MrB4D
MrB4D
Michigan
'24 Trailhunter
Ahh, that's awesome! Can't wait to see what you come up with
