406Taco
Nathan
!!Updated 10-26, see end of post!!
Hello, fellow Tacoma4g forum members.
I purchased my '24 Taco, ohh, about a year ago now. Up until this weekend, I hadn't done much with it. I use it as a daily and the modification bug just hadn't really hit me for the first year. Lately though I've been missing going off-roading with friends since selling my Jeep to buy the Tacoma. With that itch needing scratched, the modifications have finally begun. Here is what I've done so far, in rough order.
- Factory folding tonneau cover
- Dobinsons IMS suspension kit - non-reservior setup
- Dobinsons adjustable track bar
- Dobinsons adjustable rear sway bar endlinks
- Dirt King UCAs
- ECGS clamshell bushing
- Toyota axle exhaust dump
- Nomad Convoy rims in Utility Gray, 17x8.5 with +25 offset
- Falken Wildpeak A/T4W. Size 285/75
For the Dobinsons, I went with C59-820 front springs which give 2" of lift. I gave an extra 1/2" of preload to achieve the desired front lift of 2.5". For the rear, I went with C59-869V springs and Dobinsons .6" spacer, which gave approximately 1.75" of lift. I have a feeling I'll be switching them out with C59-817V springs though as I may add some permanent weight out that will cause it to sag more than I'd like.
Tire poke is not that bad at all. I'll have to get something flat to put against the tire and measure to get a precise amount of poke, but it appears to be between 1.25" - 1.5" of poke.
Parts on the way for install are RCI skid plates and rock sliders. They should arrive this coming week. Hopefully I'll have time to put them on next weekend.
Update 10-26
Added some more goodies to the Taco. Skid plates and sliders from RCI. I wasn't expecting the parts for a few more weeks, but was pleasantly surprised when they shipped early and arrived earlier this week. RCI's packaging and shipping is top notch.
I installed several RCI skid plates, which included thier engine, transmission, transfer case, rear differential, and fuel tank skids. Install was pretty straight forward when following their instructions online.
The only issue I ran into was that I had to remove the transfer case skid plate to install the rock sliders. I don't add wouldn't fault RCI for this, because its unreasonable to expect them to write in their instructions what to do for every possible scenario.
RCI does a pretty good job in their instructions for the skids on what to do if your installing another skid that uses the same mounting locations so that you are not having to unbolt stuff, which is nice.
The fit and finish of everything is pretty solid, overall. I imagine everything will perform just as good as they look.
Picture time
Future plans include an RCI front bumper with a Warn winch, front seat covers, and some better rear recovery points.
Lifted long box’s look so good!
FYI had about the same amount of poke after I put on new wheels. Didn’t think it was going to be an issue until it rained, mud was slinging all over! Ordered Rough Country fender flares the next day. They add about 1.5 inches of additional width to catch the mud and rocks.
tragisj
Alaska
Toyota Tacoma 24 OR, Toyota 4Runner 21 OR
- Dirt King UCAs
Did you swap out the UCAs yourself? Did you encounter an issue getting the through bolt out on either side?
- Nomad Convoy rims in Utility Gray, 17x8.5 with +25 offset.
Great build post and timing! Looks really pro. What do you think of the wheels and the color? I read that they look dark grey until the light hits them. Your photo looks overcast and the wheels don't look dark grey to me at all. Cool color. Thanks for sharing.
406Taco
406Taco
Nathan
I don't mind the rain and mud flinging up on the truck. I come from Jeep land, lol. I may add some ppf to the bed in front of the fender flare to prevent paint damage though.
406Taco
406Taco
Nathan
- Dirt King UCAs
I did swap out the UCA's myself. The passenger bolt wasn't an issue. The driver side is another story. The intercooler outlet is in the way. You have two choices. First, buy a new bolt and just cut the head off of the old one, then pull it out rearward. Second, lift the radiator/intercooler assembly upward about 1/16" to 1/8" by removing 6 bolts on the driver side of the assembly. I did the second option because when I first looked at it when ordering the parts, I thought nothing was going to be in the way. If the bolt is less than $25, I'd just cut the head off if you have the necessary tool to do so without damaging anything else. If you wanted to go the second option, I can post pics of the bolt locations.
I love the wheels in the utility gray color. I wanted something different than the Methods everyone else seems to be running. They do appear to change color depending on lighting. To me I've seen them appear grayish blue, light gray and dark gray.
tragisj
Alaska
I would love that. Some posts make it sound simple by removing the intercooler tube but it's never that easy so that's why I asked.
Good to hear. I am putting them on my SB Bronze Oxide for my winters. Steelie look with studs.
Thanks for posting.
406Taco
406Taco
Nathan
Thanks for posting.
Here are the photos I took while doing the job. They might not be the best, but hopefully they help out. The bolt locations are circled in red. There are 6 bolts that I removed that allowed me to be able to move the radiator/intercooler assembly upward enough to get the bolt out of the control arm.
Remove this cover. The best way to remove the retaining clips is to push the center portion downward a little, then use a pick or screwdriver to pop the clip out.
Access the hidden upper bolt by moving the black plastic piece out of the way to gain access to the hole in the radiator support. You only need to remove the upper push pin holding the plastic piece in place. Its
There are two bolts located at about the middle of the radistor, just below the intercooler outlet. The upper left one you can't see in this picture, but figured I'd cire where it is. The next photo shows it from above.
tragisj
Alaska
They potentially will be extremely helpful. This is really good content. I have scoured to the web and read as much as possible to get ready to do this with as little drama as possible.
Your way of getting the intercooler clear of the bolt head was mentioned briefly but never articulated to this level so thank you very much.
A lot of the installs get into the driver side as the problem side and suggest simply removing the intake charge pipe. It rarely seams to be that easy so your instructions may come in super handy. Well done.
My Convoys arrived:
and so did my new UCAs as well:
406Taco
406Taco
Nathan
You're welcome. You're going to really like the Convoys once you get them on.
