What is the tire pressure for 285/70/17?
Norsk
Greg
Downingtown, PA
Hello,
I recently picked up my new '24 UG Tacoma TRD Off-Road and swapped factory tires for new Falken Wildpeak AT4W SL. Should I stick to 31 PSI based on Toyota Recommendation?
Anyone with 285 SL tires running different PSI? Please share.
Thank you!
bigd9247
Dalton
2024 TRD ORP, 2018 F150 XLT
Too low......up it to
Thanks, but I'm good at 30psi. There's no need for that pressure unless you're towing or have the bed fully loaded down. Commuting to and from work at 30 has been great for me.
You can plug in your information here to get the recommended pressure: https://tiresize.com/pressure-calculator/
That comes up with 26psi, but 26 feels a little low to me. Other people do the chalk test and have also determined the correct psi to be a little lower than 30. I feel good at 30 so that's what I run.
If you like 35, then run 35. As for me, I like 30.
Nokian NAT’s SL at 35psi is too high, airing down for comfort.
Powhunter
Alberta
I’m running 28-30 on my 285/70R17 SL rated winter tires.
24Canuck
Rich
Ontario Canada...London to be exact.
2019 Tacoma
285 70 17 Wildpeak LT
32 all 4 corners.
I started with 35...little harsh but what do you expect for a LT.
If I wanted a smoother ride I would have gone P rated...but I like the ability to air down for sand and rocks if need be.
bsquaredMTB
El Paso, TX
I just got the 285/70/r17 SL Nitto Terra Grappler G3s. I'm running 32 and it feels pretty good. I have only had them a couple days so I'm still in my break in phase. I'll update if I make any changes.
My Nokian outpost NAT 285’s SL are set at 32 on the rear and 35 front.
