‘E’ Rated Tire Pressures
ORHV
Pete
MB Canada
2024 Tacoma OR Premium Hybrid
I’ve put ‘E’ rated (Firestone Destination XT) tires on my OR Hybrid. Anyone have experience with the correct air pressure to run them at? Door sticker says 30lbs, but would be to low for this ‘heavier duty’ tire. (So I was told) This would be for everyday driving on streets/highways. THX!
bigd9247
Dalton
2024 TRD ORP, 2018 F150 XLT
As far as I'm aware, E rated tires have a minimum pressure of 35psi
ORHV
Pete
MB Canada
OK, but do we run them at that? (I’m talking ON road)
bigd9247
Dalton
My F150 has E rated tires and I ran them at 35 psi for 120k miles... first set of tires lasted 100k miles. Second set is currently at 20k miles. I would air them up before towing or maxing out the payload capacity of the bed. The more air pressure, the higher the load capacity. There's charts posted online or you can use this calculator to find out the equivalent pressure of your OEM tires: https://tiresize.com/pressure-calculator/
My Tacoma does not have E rated tires, so I'm running my SL rated tires at 30psi.
What size are your new tires?
bigd9247
Dalton
I should clarify that lower air pressure will ride smoother, but higher air pressure will carry more load. Experiment with different pressures and see what you like.
ORHV
Pete
MB Canada
Same as OEM… 265/70R18
ORHV
Pete
MB Canada
Yeah, I just don’t wanna ‘wear them out’ prematurely.
StreeTaco
2024 Tacoma TrailHunter
I’m running 35s on 18” wheel, E Load. Saw a 2mpg highway increase going from 34psi up to 36psi cold. Temps get up to 39 on the road but still rides well
tkrum015
Ted
Olympia
Chalk test with a normal load add more air when running heavy.
Question for you guys. I’ve put 3500 miles on Falken E Load 275/70/18s running about 33 PSI cold. That’s the most comfortable PSI. I just bought a tread depth gauge and the outer tread is reading 16/32 and the center tread is reading 17/32. That indicates under inflation. Anyone have any idea how much more PSI I should go and have you all done a tread depth test after a few thousand miles?
tkrum015
Ted
Olympia
Was it the same in the front and back? Do a chalk test.
TacoRiz
Fort Collins, CO
2022 Toyota Tacoma
Late to this thread but how are you liking (or not) the ride quality of those tires? I'm looking at swapping my stock sport tires to 275/70/18's but there's not a ton of options between passenger / E ratings
