2024 factory SR5 wheels vs TRD Off Road wheels
Tacoscott24
Tennessee
2025 TRD OffRoad
I just purchased some trd off road wheels and tires for my 24 SR5. Both sets of wheels are 17’s however the TRD Off-road wheels have slightly larger tires. My question is would I need an alignment switching wheels and going from 245/70/17 to 265/70/17 idk if the off road wheels has a different offset. Any help would be appreciated as this is the first time I’ve swapped wheels and tires on any vehicle I’ve owned.
Slappy
tacoma , highlander
i run that size , with method 318's but those Method wheels added a slight poke , not the tires but the stock wheels on SR5 r tucked under the fenders more than normal as the 318's were 0 offset. & I got a 1 1/2" poke . I was going to add flairs anyway but had to with that much poke
Rough Country has a wide set of fender flairs that come painted or not , the fit great ,look fantastic, changed the whole look of the truck
I did not do a alinement
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20241231_004446366
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20241231_004358274
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20241231_004431740
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20241231_004407805
395North
CA
05 Taco and 22 Jeep Rubicon
Shit man, you need some help to clean out the house?
R242
Rick
Indianapolis
'24 SR 4x4 DC
I can tell you for sure the sr5 wheels are 55 offset and 24.5 lbs. at 7" wide. I would guess the OR wheels are .5" or 1" wider and 45 or 50 offset. You'll be pretty close to same as far as offset in steering clearances, but about 1" bigger which nets 1/2" lift. You could probably forgo the alignment but there will be some change in it
emidyl
Henry
Toronto
N400 Sport Prem
wheel guys would rec one, you could get away without but check in a few thou for even wear
Slappy
tacoma , highlander
No 7" wheels on the RS5 Maybe the RS
not the wheels that came on my RS5 they are 8" wide & have a crazy long barrel with the spokes on the very outside edge of the wheel
ie the wheel hugs the axles & makes them tucked way under the bed
my truck handles soo much better with the wider stance of the new wheel/tire combo i got
265/70-17's Big O BigFoot AT 10ply
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20250110_044553152
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20250110_044730321
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20250110_044654290.MP
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20250110_044611817
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels PXL_20250110_044706578.MP
R242
Rick
Indianapolis
'24 SR 4x4 DC
This is Toyota's 7 inch wheel, 17 by 7J. Measurement is from inside of rim inside to inside of rim outside, which is 7 inches. This is based on your tire patch to the road. The question is what are the 2024 OR wheels width, which have usually been 17 x 8, which by your measurement would be a 9" wide wheel.
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels 20250110_131803
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels 20250110_131811
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels 20250110_132504
2024 Tacoma 2024 factory SR5 wheels vs TRD Off Road wheels 20250110_131840
Cdizzle
p
Dirty South
2018 Tacoma DCLB
You only need alignment if you take apart suspension, not changing tires/wheels
