dunder
'26 Cayenne Turbo, '25 MB CLE53
First, let me say the sound the snorkel makes is a blast. Second, my wife has the completely opposite opinion. She hates loud cars. Naturally, the snorkel on her side of the truck is too much for her. I figure I owe her one since I bought a new car and truck for myself this year. So I decided to see what can be done.
The first option has already been posted elsewhere. Just remove the rubber cap on the lower front of the air filter box. It should be the first pic below. The was some snorkel noise reduction, but not enough.
The second attempt was to disconnect the snorkel from the air box. The air filter box fits snugly, but it’s only pressed onto the snorkel inlet. To remove the snorkel inlet, there are two bolts to be removed, and then squeeze it and pull forward to remove. Maybe it’s a little quieter, but not much. It’s the second pic.
My third effort was to insert a shop sponge into the snorkel cavity. I still can hear snorkel sucking air during hard acceleration, but that’s about it. I think this is a good compromise for noise. BTW, the sponge did not get sucked out of the cavity. The sponge is pic three.
The fourth step was to cover the air box inlet near the snorkel. It’s not a perfect fit, but the rubber cap in step one fits well enough. At this point the snorkel is silent. See pic four.
Now the final step will be a test drive with my wife tomorrow to see if the sponge is enough or do I need to use the rubber cap.
2024 Tacoma Quieting the RAI (Snorkel) Sound IMG_5839
2024 Tacoma Quieting the RAI (Snorkel) Sound IMG_5851
2024 Tacoma Quieting the RAI (Snorkel) Sound IMG_5852
2024 Tacoma Quieting the RAI (Snorkel) Sound IMG_5855
Matt
Kennett Square, PA
2024 Tacoma TRD Sport Hybrid
Has anyone tried replacing the scoop at the top of the intake with a cyclone filter cap or something like that? I don’t have the snorkel on my Tacoma, but I was thinking of having one installed at some point down the line.
I wonder if that would make any difference with the sound.
Brian2011
MASS
2024 Trail hunter
I removed the rubber cap, then disconnected the snorkel inside the inner fender and then blocked the rest of the snorkel to the passenger side, this kept the air intake from the inside fender well and under the hood.
trailhunger
2024 TH
Option #5: tell her to get used to it.
that’s what I said. Sound deadening glass, windows stay up. Keep that new car smell as long as possible.
dunder
dunder
Yeah, that didn’t work. She was complaining with the window ls up.
Strato
Tacoma 6'bed
I just turn up the radio for my wife and try to accelerate slowly and then talk about how hot or cold it is outside so she doesnt role down the window. However, she has only rode in it twice so far. Im sure she will have more to say in the future.
slater
san diego
2024 tacoma sr5/2wd, white
Dunder
Dont mean to rain on your parade, but what you did there is a very bad idea......
Get that thing out of there.....
Your blocking substantial air flow to the motor, changing air / fuel ratios & how its designed to run...
Yes, you may come back & say theres various sensors that compensate for variants, etc...
But not designed to rune with a huge blockage everyday...
just my 2 cents...
Been a ford engine tech for 32 years....
Do what you wish, with my suggestion....
Others have suggested run a factory traditional air-box & leave the snorkel there so youre not running around with a hole in your fender....
JBSwine
2022 Kia Sorento
Wait...the solution for the noise was to restrict the air flow.......wow!
slater
san diego
no idea if you still frequent this board, read my post.....
ditch the sponge, you could be doing more bad than good & has nothing to do with sponge debris....
Thats not your answer...
or dont..............................................................
dunder
dunder
I’m still here. I have the air gap between the airbox and the snorkel inlet. The Trailhunter has an optional airbox inlet which is the same size as the snorkel inlet, so my engine isn’t starved for air. I’ve also ran my truck with the snorkel inlet completely blocked. No issues.
slater
san diego
So that factory airbag also has a filtered side within the air box that works just like the factory air box that doesnt have the high snorkel & its also being utilized?
So you can run it sucking from both sides?
If so, understand, carry-on.....
If it didnt, just cuz you think there aren't issues, doesn't mean there isn't, until its to late......
making mods on these costly turbo engine, altering air / fuel ratios, isn't the best idea...
by the time you see the tale tell signs, its too late & ir- reversible damage could have accrued...
Seen it a few times...
Guys in expensive raptors, or just f150's, partially blocking charge air coolers, or custom tunes, etc...
Costing them an engine, modern engine swap is $15k today........
dunder
dunder
The whole snorkel design totally revamps the air flow for this truck. Toyota quotes a 3 horsepower reduction for the Trailhunter. I installed an aftermarket airbox that greatly improved the airflow and the truck threw codes. The Trailhunter doesn’t like too much air.
slater
san diego
shouldn't have thrown codes, the fuel system & sensors should have adjusted for the extra air, adding more fuel to adjust....
just like if your in fact restricting airflow now, the system will sense that & compensate in a bad way...
just cuz its not throwing a light, doesnt mean its not leaning out...
