Duce95
Duce95
Big Deezy
2024 TRD Off-Road Premium
yes sir, checked and double checked before I turned the power on. I didn’t have the engine lights before I wasn’t getting power to the head unit. I checked the fuses and then I got those .initially I just didn’t get power to the radio.
Yeah do you have an update?
Dansflhti
Nova Scotia
Am I correct in assuming that the stock OEM audio amp in the upgraded JBL is the module mounted to the back of the 14" display?
A question for people who have already installed the Beat Sonic amp. What gain settings did you use?
The Beat Sonic install video for the Tacoma showed the rear gain straight up/down and the front straight across. So I'm was thinking they meant half way on the rear and 3/4 way on the front. But now I am wondering if that front setting was 1/4, not 3/4. I know that the front speaker on the JBL seems to dominate everything else.
Mine came a few days ago, but it is insanely cold and it will be this weekend or next week before I do my install. I plan to put it behind the screen, so hoping to nail the gain settings on the first go.
Thanks for any advice!
Front 1-2:00 rear 12:00. But a few turned the rear up to 1-2:00?
Thanks @MT-Taco! It does make sense to maybe try boosting the rear a bit more. But when I did that through the Toyota sound settings, I didn't think it sounded any better, and maybe even worse.
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
It doesn’t matter. Front and rear both use the front gain. I believe the rear on the Beatsonic is for nav, etc.
Interesting to know and that does make sense because you can adjust those sounds independently. I knew that there was more knowledge about this on the forum than I had.
Thanks for that input.
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
I should have prefaced this by saying this is for the JBL equipped units. The standard might be different.
BronzeOR
Hawaii
24 off road premium
Did anyone change the “speaker volume” setting with Carista and also install the beatsonic amp? I had my speaker volume set to 10 units and when installed beatsonic with front gain at 2oclock position I had a lot of distortion. I’m wondering if I set the “speaker volume” setting back to factory and raise the gain on beatsonic amp up from its current position which is at between 12-1 o clock, if that would result it slightly better results.
