Bjl0719
Brandon
West Virginia
Hi everyone. I added a cap to my truck and didn't want to lose my cameras. I found this kit online. https://www.ggoffroad.com/store/p/digital-rearview-camera-relocation-kit-tundra-22-24-tacoma-24 and thought I'd give it a try.
It worked great. You have to be willing to pull down your headliner and remove some panels, but it's worth it in the end. The job took me several hours, but as one of the first, I had to adapt Tundra instructions to make it work. If I had to do it knowing what I know now, it'd probably take me around 3 hours.
If you're putting on a cap or a bed rack, this is a pretty good solution. The staff at ggoffroad.com is very helpful and answer questions quickly. I for sure recommend the product.
What topper is that? That’s super clean
is that the ARE bed topper?
evlfred
Monte
Idaho
so my bed view camera is like mirrored now after the relocation. Does yours look like that? Maybe send a picture?
Tacoyaki
Tacoma TRD Off-Road
How possible is it to do this with a camper shell already installed? Access is pretty limited to the rear. My Tune camper has a window, but still not much room to maneuver the rear spoiler.
evlfred
Monte
Idaho
buy the camera and harness, that's what I did cause I wanted to be easily able to make it stock again. I may be selling a camera as I bought one that works fine but had a broken lock on the connector, I got a new one thinking that was the issue but it was the cable instead.
Tacoyaki
Tacoma TRD Off-Road
That's what I was thinking also. Looking at the space between the spoiler and my Tune, it looks impossible remove.
Let me know how much you want for the camera.
Are the 2 cameras (rear view mirror and bed) swappable (the connectors look the same)?
evlfred
Monte
Idaho
no they are completely different, you can save some money on the harness and get a tundra one too, thats what I did. I'd do $125 for the camera which is half price
Tacoyaki
Tacoma TRD Off-Road
Great!
Do you know the PN for the Tundra harness?
andrewleader
Andrew
Washington State
Anyone having overheating issues with their redirected external rear view mirror camera? Mine is mounted on the back of my Tune, and when it’s sunny and hot (70+ degrees F), the mirror will flash black for a half second every few minutes. When it’s cooler out, zero issues (like all this winter it was fine). Does NOT seem to be bump/vibration related, definitely heat related. I saw this happen a week ago when it was 70’s and then this last week it was colder, and then today back warmer and it happened again after the car sat out in the sun for a bit.
I suspect this design soaks up the sun heat when the direct sun is on it, wonder if maybe one of those wireless ones would have been designed to handle the heat better…
Tacoyaki
Tacoma TRD Off-Road
Haven't had a chance to relocate, but this is a concern since it hits triple digits where I am. I'll report back if I have the same issue, especially since it's likely summer when I'll have time to attempt the relocation/install.
bking
bking
Bernie
2024 Tacoma TRD Offroad
I had trouble with the relocated camera when it was on the bracket and pointed through the rear window of my Truck. It wasn't heat so much as it was the jostling around. I since did a permanent hole through mount on my cap. I'm working on a more robust design, but this has been great. I designed and printed these on my 3D Printer
2024 Tacoma Digital Rearview and Bed Camera Relocation with my Topper on 2024 Tacoma IMG_1323
2024 Tacoma Digital Rearview and Bed Camera Relocation with my Topper on 2024 Tacoma IMG_1329 2
andrewleader
Andrew
Washington State
That looks really nice built into your truck topper!
Here's a GIF of the camera overheating issue, gonna contact GG Offroad today, but posting it here if others see the same issue.
Here's how mine looks on the outside (using the stock external mount they provided, bolted onto the t-track, I didn't have any vibrating / bouncing issues).
2024 Tacoma Digital Rearview and Bed Camera Relocation with my Topper on 2024 Tacoma 1745256133864-r4
TomColorado
2024 Tacoma Digital Rearview and Bed Camera Relocation with my Topper on 2024 Tacoma {filename}
would you be willing to share the file you 3D printed with me? I need to redo mine. I’m having awful flickering. I can dm my email or if you can dm the file. Would really save me.
Daverole
DAVE
It’s been great. Right now I am using the suction cup mount, but I designed and printed a hole through mount. I haven’t had time to paint and install it yet. As for warranty, probably not. I think they would warranty the screen in the rearview mirror. But probably not that Camera that I moved. There’s no way to revert it without taking your cap off. I figure it’s worth the risk since it will be worthless without moving it
Hello did you ever design a hole through mount for the rearview mirror camera from GG off-road?
