Extended Rear Axle Breather Vent
StreeTaco
2024 Tacoma TrailHunter
What’s up all, just finished up this easy mod to extend the rear axle breather lines.. The factory vent is a joke, it will do its job well, but only if water doesn’t get over the top of the chunk. I shopped the ARB brand extension kit, as well as online knock offs. I’m sure they work great, but since the front diff, t-case, and tranny are already vented up pretty high, I opted to only do this for the rear.
The nipple and vent came from Amzon , the 5/16” fuel line and clamps, from the local hardware store. 8’ of line did well. Ran the hose out of the way of any moving parts and zip tied in a neat fashion. Terminated behind passenger taillight. Good to go.
Also added this cool hitch slider thingy.
2024 Tacoma Extended Rear Axle Breather Vent 300C16AB-F528-4584-AD04-A5CDF1416965
2024 Tacoma Extended Rear Axle Breather Vent E22EB92D-8C2D-4390-8C16-3F497DEEADE4
2024 Tacoma Extended Rear Axle Breather Vent 3F12A4EC-07D5-441F-8DF9-C8315B8BB7A3
2024 Tacoma Extended Rear Axle Breather Vent E9D0E682-001D-4CE5-8ED5-BED22AEF7A42
100% doing this - do you know where the front diff brewrher comes out
Pappy
Intermountain West
I will add this to my list of good things to do. I used that fitting to extend the breathers on my Gen1 4Runner. The barb fitting is a Toyota part. I harvested mine from 22re engines. It's the barb fitting off the plenum to the brake booster (IIRC), 90404-51319, ~$13.
Fortunately, I have a stash of those fittings.
2024 Tacoma Extended Rear Axle Breather Vent breather extension-sm
Reactions: oxi
Powhunter
Alberta
Thanks for write up! I’ve had the parts to do this for a couple months. I’ll likely do it when I swap the winter tires out next month.
Was it difficult to remove the taillight?
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
I know generations are different, but on my old 2010 SR5 BOTT, I ran the rear diff breather up into the gas cap area using Camry lines and fittings.
2024 Tacoma Extended Rear Axle Breather Vent DSCI0055
2024 Tacoma Extended Rear Axle Breather Vent DSCN1635
StreeTaco
StreeTaco
No. Two 10mil bolts, and two plastic clips. Pretty much fell out
Reactions: oxi
Sancheesy
Shawn
Ontario
Is the nipple the same size as the second gen?
Bigt
Az
24 sr5
what size are the threads? or a link to the amzn parts you bought
Andrace
2024 TRD Off-Road 6MT
Thinking it’s in the firewall somewhere
They're on the drivers side of the engine bay right next to and at the height of the top of the shock tower. I spotted them while installing the ARK splash shields, and they are more exposed than I was expecting. l was left wondering why the factory engineers thought that was a good location.
StreeTaco
StreeTaco
inside the engine bay? Not under the wheel well? Would like to locate and extend these.
Andrace
StreeTaco
StreeTaco
Correct, there is not much of a partition between the engine bay and wheel well where they are located.
See this diagram, there are metal pipes up from the diff and transfer case, and then a short hose that connects the tube to the breathers. It would be simple to extend those hoses into a relocated breather.
https://autoparts.toyotaofdecatur.com/products/product/tube-differential-breather-4153304020#popup-1
OK cool, so it’s the two tubes that share the single breather? Thx for the diagram
