AlpaRex Double Tap fog lights
Install done today. Looks OEM until you use them. Far brighter, simply turn your fogs off/on to change from clear to amber and they came with a pigtail to tie them into you turn signal making them sequential.
2024 Tacoma AlpaRex Double Tap fog lights IMG_6063
2024 Tacoma AlpaRex Double Tap fog lights IMG_6062
2024 Tacoma AlpaRex Double Tap fog lights IMG_6075
evlfred
Monte
Idaho
how was the install, if you don't want the turn is that an option?
Install was easy, took about 1.5 hours you HAVE to take the front bumper cover off. AlphaRex instructions are for the Tundra! They definitely need to update the Tacoma instructions. Takes less than five minutes to add the sequence harness. It just plugs into the turn signals.
Forgot to add this! You need to push this red pin in on each side to get the cover to release where it connects to the fenders!
2024 Tacoma AlpaRex Double Tap fog lights IMG_6070
Bob
Toms River, NJ
Wondering what Tacoma model you installed the Alpharex Fog Lights in?
I have an issue with the OEM harness - 2 different size 3 pin connectors.
I have the TRD Pro
2024 Tacoma AlpaRex Double Tap fog lights IMG_5510
2024 Tacoma AlpaRex Double Tap fog lights IMG_5507
Bob
Toms River, NJ
Hmm. Tech support closes in an hour if I remember right. They helped a bunch when I installed the nova headlights.
888.924.5888
Appreciate it, I spoke to them last week, they don’t have an answer or a harness. Wanted me to ask around what other Tacomas had. They believe that my truck was built early stages of production and the OEM harness has changed. Alpharex is checking with distributors and installers if they’ve run into this issue. Worst case I was told to run to an AUX switch.
I’m fishing for suggestions too
I have the TRD Pro
Late May built TRD OffRoad, was plug and play. Does the Pro come with Ridgid fogs? That could be the problem??
That sucks..
Bob
Toms River, NJ
Yes, exactly that, which is the reason I verified before purchase that it would work, Rigid Lights. I just can’t believe I’m the only one that’s run into this problem. That’s the reason I’m on here looking for someone else.
Drunkmonkey
Soflo
I have a pro as well and just got my lights in. ( to bad I didn’t see this earlier )
Is there an easy way to look at the connectors before taking the bumper off/lights out?
I can check tomorrow if there is. I have a 25 pro
From above you might be able to reach down and feel the plug? Unplugging it is probably doable but plugging it back in may be a challenge. There is a fair amount of room.
Drunkmonkey
Soflo
I tried this morning unfortunately no way to really get back there to look or feel without taking more of the truck apart then I had time to do this morning
Bob
Toms River, NJ
Let us know when you get the chance to install, interested to see if the 2025 Pro has the harness that matches the harness that comes with the Alpharex fog lights.
I’m still waiting for Alpharex to dig deeper into this issue.
