Pap
Pap
North Jrzy
24 Trail Hunter
I didn't have any trouble with the passenger side. The speaker was slightly in the way so I just bent it up a bit so I could get the screw driver in there. The whole job took about an hour.
Pap
Pap
North Jrzy
24 Trail Hunter
C4 rock sliders arrived today. Prepping for paint... degreased the bare steel. Will apply POR15 base coat tomorrow and will top coat.
Base and top coat just finished
25TacomaTRDSport
2025 Toyota Tacoma TRD Sport
Hi, can you provide me with the information on the air intake? Your ride looks nice.
25TacomaTRDSport
Oh I didn't know that, so I could get it at the dealership?
You can buy it sure, but I don't think you're going to get the desired results. Unless you want to just have it as a nonfunctional, showpiece that serves no purpose. TH has cutouts and what not where that mounts into the body.
25TacomaTRDSport
No, I'm going to go all the way and get the full functionality of the snorkel.
Pap
Pap
North Jrzy
24 Trail Hunter
It's not set up as a snorkel. It's made to reduce the dust going into the intake by pulling air higher up. Still questionable. I believe it can be sealed so you can go snorkeling ?
bronzebeast
So Cal
2025 DCLB
Today I added dobinson springs to the front to compensate the newly added front bumper/ winch weight. It also raised the truck by about 1 1/2". I also order the the rears but they are on backorder so in the mean time, I installed 1" peak spacers.
Changing the suspension on this Tacoma might simply be the easiest I've done on any vehicle. Such a pleasure.
Hey man, so my bumper and winch set up are going to be about 150lbs I’m on a TRD offroad. I want to add dobinsons coils but I’m curious, do you feel like the 822’s are good with that weight? Or do they feel a bit stiff to you? Thanks!
Pap
Pap
North Jrzy
24 Trail Hunter
The 822's are perfect. No difference in the ride at all.
Pap
Pap
North Jrzy
24 Trail Hunter
Today I ended up going with falken wildpeak at4w 35x11.5 tires. Just needed to remove the crash plates in the front wheel wells. Other than that, no rubbing on anything. Perfect fit! The wildpeaks ride a little stiffer than the toyos even be load rating c. Acceptable and very minor difference in road behavior. Going out in the woods tomorrow to give them a go.
