New TRD pro ride uneven…
@tacorancher Good idea about the wheels being straight - I'm pretty sure that would affect the front end. @james cole's difference is in the back, so it is probably not as important, not that I am a suspension engineer.
The entire body lifts all the way to the back - not as much as the front bug it does - I’ve taken some measurements and it def makes a difference
Xjim
Jim
Central Ohio
Hello Guys…
Noticed today, the suspension on my TRD pro is about one inch taller on the passenger side rear than the drivers side… is this normal and how to fix it?
Thanks!
JC
My 2005 OR was uneven too, ended up replacing rear leaf spring under warranty.
My 2024 Sport though gives me anxiety with the computer programming too. I also had problems with the tire pressure disappearing when I set it, then after many months it stayed put. Recently it decided to disappear again and I couldn’t get it to stay put again. So I changed cluster to a different background and it disappeared for the first few times of setting it but now it has decided to stay!
2024 Tacoma New TRD pro ride uneven… 1744042433599-bz
The tire pressure disappearing is a known issue - please describe how you got it to stay
He didn't. It will disappear again. It's a well known issue and Toyota has addressed it as a normal part of the OS.
Xjim
Jim
Central Ohio
Yes it is a well known issue and mine has reappeared and I got a video of it.
james cole
Bronco
I see the TPMS issue... but what is worse is that you have to push the back button everytime to delete the PSB Message, EVERYTIME????
Whats up Toyota?
Are you guys ok with 20 reminders every time you start your truck?
