2025 TRD Pro rust under front seats? Pictures added
MIne did that when my truck was new if I pushed my upper body against the seat back. But then it stopped and the last time I tried to make it do that it wouldn't, no matter how hard I pushed. Maybe some of the parts just need to wear in. I also stopped using the suspension for on road driving, so that might be it too.
pepco
pepco
Jim
Raleigh NC
2024 LC, 2025 Tacoma TRD Pro
Mine is the side bolster where the seat meets the plastic with controls. From what I can tell its a plastic ridge on bottom bolster cushion the catches a metal piece when you press down on bolster.I can pull the plastic ridge away from the metal piece with my finger and it misses the metal , but when I let go it forms back to where it was. Weird
Appaloosa2
Nashville Tn
25 Sport LB Premium
I just took delivery of a 2025 TRD Pro and was looking under the front seats and saw rust on some of the metal parts. Looks like a metal rod and its brackets. Both seats have this. Should I be concerned? Anyone else noticed this?
Hate to say this but all brands of vehicles do this from condensation.
Wow, that is weird.
Mine does not do anything like that and you might want to see what your dealer has to say about this. These seats seem like they are kind of one off prototypes, and not really fully sorted production items.
Yes, that is true. There are some unpainted metal pieces under the hood that develop surface rust, and it isn't really a problem either, except for cosmetics.
Big Dawgs Toyota Tuning
Quez
Nashville
www.bigdawgstoyotatuning.com
Do any your guys seats sound like there's metal on metal hitting underneath the seat? Mine has this weird metal on metal noise if I hit a bump hard enough or if I push my leg down. I don't think it's related to how much air is in the "suspension" system or anything. It's only on the front right side of the drivers seat and the front left side of the passenger seat.
pepco
pepco
Jim
Raleigh NC
Mine were what the tech said was loop clips that had come undone. They were behind the panel where the seat controls are. You could see the difference in the passenger seat when looking under them. You could see seat fabric not tucked up tight like on the drivers side because of the clips. Also it started when I would get into seat, it would make a popping sound, then it started making more sounds when I moved around in seat, like when my weight shifted. I haven't had a problem since tech fixed the clips, no noise at all. This started when I 1st took delivery.
