Drifte
Colton
Iowa
24 Tacoma, 20 RAV4, 10 Tundra, 99 C5
Installed this intake with high hopes of a clean and easy install. K&N does a great shop in r&d and fitment always seems on point. However, this wasn't entirely thr case with this new intake..I chose it over others for the full inlet replacement. Where those vacuum hoses all tie together is a mess, and the provided hose too small i.d to fit on. Seems like a few small hose clamps should be used here and there but arent. It was also missing a bolt to hold the airbox down. The holes in the lid of the airbox dont align with the airbox itself and took some effort (one shown in first pic).
Once installed it looks very nice, turbo noise in much increased at initial spool up. I like the aluminum flange that ties the turbo to intake they added. I've attached a few images from the process. I'll be looking for ways to better finish the vacuum lines though, those appear like a complete after thought from K&N.
Any questions feel free to ask. Kit does come with b/w install instructions, the website has them in color. The MAF orientation can be confusing and the wire is a little tight once in place.
2024 Tacoma K&N 63 series air intake review + sound clip video (on gas 2024+ Tacoma 4th gen) 20250414_214844
2 bolts were easy, the next to were off enough they were very difficult to get started.
2024 Tacoma K&N 63 series air intake review + sound clip video (on gas 2024+ Tacoma 4th gen) 20250414_215539
Completed install, does look very nice IMO.
2024 Tacoma K&N 63 series air intake review + sound clip video (on gas 2024+ Tacoma 4th gen) 20250414_212735
Mess of vacuum hoses.
2024 Tacoma K&N 63 series air intake review + sound clip video (on gas 2024+ Tacoma 4th gen) 20250414_212741
2024 Tacoma K&N 63 series air intake review + sound clip video (on gas 2024+ Tacoma 4th gen) 20250414_203131
Factory turbo inlet silencer "manifold"
2024 Tacoma K&N 63 series air intake review + sound clip video (on gas 2024+ Tacoma 4th gen) 20250414_203846
K&N turbo airhorn installed.
Part throttle initial boost is the most noisy, the "dose" from no bov is fun too.
Drifte
Drifte
Colton
Iowa
hoodouken
Las Vegas
Oh, also I come from an import tuner background where typically each significant mod requires an tune. The numbers they're showing are pretty significant, which is good but how far does that throw off the air/fuel?
Will-Stillen
Will
Costa Mesa, CA
stillen.com
2008 Toyota Tacoma
Import tuner background. I know this is a Taco forum but I'm interest in hearing what else you own? haha
hoodouken
Las Vegas
All started in 2002.
I had a 1997 Prelude Type SH. Sold it and moved to a 2004 STi. Sold that and got a 2012 STi.
Drifte
Drifte
Colton
Iowa
As do I, I would like to monitor afr but dont have anything setup at the moment. Im undecided on adding a tune as well, I try to leave the tinkering to the fun cars and not the daily, but sometimes cant help myself. I solely added this intake for something fun to do. I used to tune my dsms, subarus, bmw, and as of now LS based vehicles. With the BMW anyway the computer could handle significant afr and timing needs compared to how things started with the DSMs. I expect the new Toyota to be similar.
Will-Stillen
Will
Costa Mesa, CA
stillen.com
2008 Toyota Tacoma
I had a 97 Lude as well. haha These trucks are not as bad as adding parts to subies. I have a good amount of Subaru back ground as well. You can't even add a new shift knob with out getting a tune for them. lol
If you're considering a intake for your new Tacoma check ours out as well. If you ever need any parts from us feel free to message me. I can get you better prices than what's listed on our site.
https://stillen.com/collections/int...ta-tacoma-trupower-by-stillen-cold-air-intake
Ace-ington
New member here, I just installed this intake and I very much agree with the mess of the vacuum lines. I have been having some issue with mine it's been saying reduced engine power message, which i feel like it's a vacuum hose issue but could be wrong
2024 Tacoma K&N 63 series air intake review + sound clip video (on gas 2024+ Tacoma 4th gen) 1000002970
Drifte
Drifte
Colton
Iowa
Is that the burger catch can? I plan to get that as well, already had some oil in the turbo inlet
I'm debating removing the k&n because of the vacuum lines, I haven't had an issue but it's such a hack work around I cant believe k&n released it.
Ace-ington
Yeah it's the burger motorsports catch can, I ran the k&n intake first before the catch can and had the issue, today I went to canadian tire and bought a clamp for the hose that has the clamp on the one side so I will see if that made a y difference. The message usually shows up after one or 2 drives.
Ace-ington
So I have now had a CEL with the code P2c90, I did a bit of searching and by the sounds of it that is a common issue with adding aftermarket intakes with these newer vehicles, shows up under partial throttle i think. the other thing i saw also from my reader shows that my long term fuel trim was showing -17% which from my understanding is it is running rich now (shouldn't be outside of +10% to -10%) i tightened everything up more and it is showing -11.7% and when I drive it goes to -9%. What I got from the gr corolla page was that the vacuum sensor is outside of it range with the freer flowing intake.
Does anyone know the diameter of the tubing for this intake? (Dont have time to check mine), usually anything above 3 inch most vehicles will throw a code
GMak621
George
Røgue Valley
24 Tacoma TRD ØR
Save yourselves the headache and go with the SXTH Element intake.
Ace-ington
Looking more into this it sounds like alot of intakes have issue, even SXTH Element has this same problem with the GR Corollas and even catch cans
