Eibach 24+ Toyota Tacoma Stage 2 Pro Truck Lift Kit - Panda Motorworks
Aleah@PandaMotorworks
aleah
saint peters missouri
2021 ford bronco
PRO-TRUCK-LIFT Stage 2 Coilover Suspension System
Take your Tacoma's suspension to the next level with the Eibach PRO-TRUCK-LIFT KIT (STAGE 2), engineered for precision performance both on and off the road. This advanced system features threaded height-adjustable front coilovers, offering customizable ride height, and utilizes the same high-performance rear shocks as the STAGE 1 setup for consistent handling across terrains.
The PRO-TRUCK-COILOVER 2.0s boast an extended travel monotube design with variable force valving, delivering superior control on highways and unmatched traction when tackling off-road trails. Compatible with Eibach’s championship-winning ERO Off-Road Race Springs, this system allows for flexible tuning to accommodate everything from factory-weight vehicles to fully loaded off-road rigs.
Specifications
Championship-Winning Performance: Eibach’s top-quality suspension utilizes race-proven technology for unmatched durability and handling.
Balanced Ride Quality: Designed to deliver superior off-road capability while maintaining exceptional on-road comfort.
Front Lift Capability: Fine-tune your setup with up to +2.5" of front ride height adjustment for optimal clearance and performance.
Rear Lift Capability: Performance shocks accommodate up to +1.5" of lift for a balanced setup.
Installation: Pre-assembled coilovers ensure a hassle-free, direct bolt-on installation, with factory-level rear ride height right out of the box.
Seamless Compatibility: Built to work seamlessly with OEM control arms, maintaining durability without accelerating wear on OEM bushings and ball joints.
Full Suspension Upgrade: The kit features front PTC 2.0 Coilovers, rear PRO-LIFT-KIT springs, and PRO-TRUCK Sport shocks, delivering a balanced lift and superior handling.
Fitment: 2024 Toyota Tacoma, 2025 Toyota Tacoma
Made in the USA: Manufactured by Eibach, ensuring top-tier craftsmanship and durability.
Limited Lifetime Warranty: Backed by Eibach for long-term reliability and performance.
2024 Tacoma Eibach 24+ Toyota Tacoma Stage 2 Pro Truck Lift Kit - Panda Motorworks eibach-eibach-24-toyota-tacoma-stage-2-pro-truck-lift-kit-eibe86-82-105-01-22-panda-motorwork
aleah
2021 ford bronco
Interested in this setup? Shoot me a message and I may be able to hook you up with a forum exclusive discount! Happy to answer any questions you may have as well!
uknat
Nat
San Diego
2024 TRD Offroad
howdy. I've been looking into this setup and would love to purchase from someone with experience. Shot you a DM
DougW
Doug
Utah
I installed the Eibach PRO-TRUCK-LIFT Stage 2R about a month ago on my Tacoma TRD-Sport Premium. The installation went smoothly, taking an afternoon with the right tools and some experience. All parts fit well, no issues. I adjusted the front spring compression to go from a 3" lift to my preferred 2", giving a sharp but practical look. On the road, it handles bumps and dips nicely, making drives comfortable and smooth. It lost its stiff road truck feel, which I loved when cornering or racing on the road, but the tradeoff is worth it. Off-road, it’s a big step up. Now, I can hit rough terrain—rocks, ruts, washboards—faster and stay composed. The shocks absorb it all, keeping things steady. Whether it’s daily driving or off-road trips, the Stage 2R balances ride quality and performance well. Eibach did a great job—I’m happy with this upgrade and would recommend it!
tkrum015
Ted
Olympia
@DougW. Was the 2.5 adjustment for more of a level look with the rear or do you still have a little rake? Did the Icon UCA help get a good alignment? Any vibrations in the front from the lift? Take more pictures when you get a chance. Thanks
lane.bax
Lane
MT
2025 Tacoma OffRoad
Specifications
eibach-eibach-24-toyota-tacoma-stage-2-pro-truck-lift-kit-eibe86-82-105-01-22-panda-motorworks...jpg
Do you know or have access to the collapsed and full extended length of these?
thank you.
DougW
Doug
Utah
thank you.
I've looked everywhere and could not find any information. I did an in-depth Grok search and still no luck. I should have measured them when they were still in the box.
DougW
Doug
Utah
I still have a little rake. The closer you can stay to stock height, the less likely you are to stress needle bearings, etc. Alignment was done at my local Toyota dealer after I installed and upgraded to TRD rims. They said everything was fine, no issues. I stayed with stock UCAs. The front is 1" less than the back. I have not experienced any vibrations. Everything feels great.
tkrum015
Ted
Olympia
Very nice, thanks . Did this also include the rear springs? Can you get some center of hub to bottom of fender measurements front and rear?
tkrum015
Ted
Olympia
Specifications
eibach-eibach-24-toyota-tacoma-stage-2-pro-truck-lift-kit-eibe86-82-105-01-22-panda-motorwork...webp
How are the front shocks adjusted to fine tune my front ride heights?
