Brake controller harness for 4th gen Tacoma?
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
I was investigating on the web and I found this Curt Trailer Brake Control Harness, I was wondering if once we have this installed we only need to plug the brake controller and it should be good to go.
Once again I am not sure so I would like to get your thoughts
The truck does not have a place for that to plug in.
GatoCake
Toyota Tacoma TRD Off Road 2024
I found this document which says there is a place but I have not looked for it yet
Truckeeskibum
Neil
Truckee, CA
2007 TRD Sport Long Bed
That document has a date of 7/2/2020 on the bottom. Can't be for a 4th gen Tacoma.
Sorry.
GatoCake
I didn’t see that, my bad
Thank you though
4thGenOffRd
Guy
Merced, CA
2024 Tacoma Off Road
I’m seeing many more 4th gen Tacomas on the road. Some company is going capitalize on a wired solution for those in need. Until then, the Curt Bluetooth does the job. I towed a 19ft travel trailer over the Sierra Nevada on multiple trips using the Curt and it works fine.
Camperbunga
Connie
PA
2025 tacoma TRD OR
[/if you find the receptor for that plug in your 2024 Tacoma let us all know. None of us can find it. It should be in harness under side panel near brake. Don’t buy that til you find it. If you don’t, go for the tekonsha wireless. Much better that the Kurt wireless.
Those instructions are for a Tundra, not a Tacoma.
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
GatoCake
Unless something has recently changed, the Tacoma does not have the wiring.
have you installed a brake controller recently?
I mean I want to know if there is a way to do it
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
Have you read this thread? The wires are not there. Did you read the other thread? The 4R manual shows a prewire. The Tacoma manual does not. This information is readily available. There is a write up on how to install one floating around.
PerpetualTraveler
kathy
2024Tacoma SR
This won't work, the harness for it is not even there, it also need the brake controller ECU which is also missing, the whole harness is different so we cannot even buy the ecu and plug it
Please called Toyota Customer Engagement and register your complaint. The more that do this the quicker we’ll have a Toyota wiring fix.
Camperbunga
Connie
PA
2025 tacoma TRD OR
I installed Tekonsha wireless. Much better than the Kurt which I already had. Tekonsha more $$ but worth it because it’s not phone dependent like Kurt. There’s a separate hand held controller rather than using your phone as Kurt requires
GatoCake
Thank you !
I’ll try it out !
PerpetualTraveler
kathy
2024Tacoma SR
Glad you had a good experience. I have a Curt and want my old Tekonsha
Prodigy P3 back šŸ˜’
