Electric Running Boards that fit TRD Pro?
james cole
Bronco
Hello guys,
Not having any luck finding electric running boards for my TRD Pro, Im 6'2'' and truck is a bit to tall for me surely most people have this problem....
Let me know,
JC
Bravada
S.E. Texas
Hello guys,
Let me know,
JC
I really like the electric running boards on my limited, should fit a pro. I assume Toyota sells them as an add on.
Drunkmonkey
Soflo
The rough country e boards will fit the pro, have them on mine. There is a few alterations to their instructions you have to make but they will work.
james cole
Bronco
Do you happen to have a picture retracted and lowered?
Drunkmonkey
Soflo
@Drunkmonkey - Do you have a list of the alterations?
It’s not anything complicated.
The ground to go under the hood just goes to the hybrid inverter which is exactly where the battery would be on a none hybrid there’s a nut between the fuse box and the inverter.
the power I just put right to the power going into the fuse box again there is a nut.
under the truck the control box didn’t fit where they say to put it because of the frame / under body differences. If you mount the brackets for the steps the box can be installed in its original intended location however it’ll be on a slight angle instead of straight on that’s it.
Any issues with them? How do they feel getting in and out?
Thanks.
