Alignment Specs
Richm
Richard
VT
2024 TRD Off Road, 2020 RAV4 XLE
New Grant Alloy wheels and 285/70r 17 Falken Rubitrek tires and then
2024 Tacoma Alignment Specs IMG_0355
Installed the Peak Suspension 1 1/4” front strut spacer and 1” rear spring spacer and now need an alignment. Measuring the bottom lip on the rockers, there’s 3/4” rake. Contemplating pulling the front and doing a full 2” spacer………….that would level it out according to the rocker measurements and gain a little more in the front wheel well…
But anyways, I’ve been to 2 places and they can’t align it because their equipment hasn’t been updated to include the 24’s. Dealer is like 3 weeks out and I don’tt really want to wait that long…..
Where has everyone else been getting theirs done? Could the alignment shop just put it in as a 23 and then align it to certain specs? If so does anyone know the specs?
thanks in advance!
thanks in advance!
My local Goodyear has the 2024 Tacoma alignment spec. I'm shocked you're dealership didn't.
I would expect the 24 spec to hold for 25.
Goodyear said they get the updates for new models once per year, usually in January.
Richm
Richm
Richard
VT
I’m sure the dealership does have the specs. I’ve been to 2 tire shops that do alignments and they haven’t been able to do it.
The dealer is a little over 2 weeks out for appointments right now so was hoping to find a way to do it before that long of a wait.
Ah. Misunderstood. Took dealer as 3wk out to be they wouldn't be getting their update until then. Not that you already had an appt then.
Slappy
tacoma , highlander
i did mine at Big O tires & yes it did need a alignment ?
tkrum015
Ted
Olympia
Did you change more than tires and wheels? Looks good.
Slappy
tacoma , highlander
just tires , wheels
went back to deal with a vibration at 72mph 2 weeks after the new tires
had a slight odd feel to the steering wheel
so I had them do the alignment at the same time
one wheel was slightly outta balance
and then the issues with the front end .
matter of an old habit when I get new tires I always align 2 protect my investment ?
yeah
here ya go
Now i can take my hands off the wheel & she tracks straight down the freeway at 70 pmh
So odd.. my dealer shows caster needs to be 2.8+… yours shows a much lower range and the way you had it initially would have passed spec according to my readout from the dealer ..see below … is it different for different trims?
2024 Tacoma Alignment Specs IMG_6880
exia
los angeles
24 tacoma hybrid Trd OR
How much was the alignment at the dealer? I just got 285 on a +15 offset with a local shop. And I feel it's leaning to the left. In addition, when it is straight, it may be sitting more to the left. Or it just might be idk.
I attached my sheet
Pappy
Albuquerque, NM
I just had my truck aligned at the dealer after doing a lift. They had the 2024 specs, but not the 2025. You would think the numbers would be the same, but they are not. They had to track down the 2025 specs and enter them in.
2024 Tacoma Alignment Specs 1750119844451-vc
So does this show the 24 or 25
