Tacoma Sport shudder / vibration
Stringent
J
Got you on a technicality - I'm sure lots of people are driving 75 mph, and that's not really ticket territory.
Maybe you can get the tires road force balanced - that would allow them to simulate the problem speed. If the tires are fine, then it pretty much has to be the truck.
Good luck.
Exactly what they did in the visit. Because they won't drive it, they threw up their hands and said "Sorry". Seems pretty sleaze ballish.
I know that there are dealer training events. Maybe they spend most of their time learning how to blow off their customers.
I have a good dealer at the moment, and they really want to make their customers happy. But most Toyota dealers I have dealt with in the past don't want to do anything beyond the minimum they can get away with.
cf86
Rob
Michigan
23 Tacoma TRD Off Road
I have a 23 TRD OffRoad - With 6000 miles on it I took it in for the shudder and they found out the drive shaft was out of balance. They replaced the drive shaft and the rear wheel bearings in it.
Reptar
Michigan
2025 Tacoma TRD OR LB
I have a stock 2025 TRD OR with a 6ft bed and only 800 miles on it and am experiencing vibration issues around 25-35mph. It's not very noticeable when you accelerate past 35mph but when driving at a constant speed in that range it can be very annoying. It feels like something is reaching a natural frequency and inducing a vibration (tires, cv joints, driveshaft, etc). When slowing down to a stop it's also noticeable. I took it in today and the dealer drove my truck and another Tacoma (without me) and claimed that vibration is normal as the other Tacoma did it as well. I hopped in an SR5 with the service manager and we were unable to detect the same issue. The dealer did nothing other than a test drive of my truck and another truck. I am taking it back next week and dropping it off for an extended diagnosis and they stated they would open up a complaint with Toyota.
Same issue from other forums.
https://www.tacomaworld.com/threads/trailhunter-vibration-at-30-40-test-drive.852101/
https://www.tacomaworld.com/threads/vibration-from-35-50-in-the-trd-pro.849245/
Badgertaco
canada
2024 tacoma trd offroad
Ok i have 25,000 kms on my tacoma now, still have the vibration over 90 kph. Just noticed my front tires are cupping now too so maybe front end problems on my end but keep me posted if they figure anything out please, thanks
Slappy
tacoma , highlander
alignment needed
i paid my tire shop $125 & yes it was outta spec
runs smooth & straight now
Tacoscott24
Tennessee
2025 TRD OffRoad
I hope this helps. I have a 2025 Off Road 6ft bed that has only 700 miles on it. I took it to the dealer last week and had them road force balance my tires. They found out that my two rear tires were out of whack and didn’t even want to road force balance them after having them replaced under warranty. The two existing front tires and the two new rear tires were road balanced, and it rides like a dream. Definitely have them check it out. I would say it’s tires for sure.
Reptar
Michigan
Thanks for the tip. I'll see if I can get them to road force balance to see if the tires are jacked.
Did you have a similar issue in a certain speed range?
Tacoscott24
Tennessee
2025 TRD OffRoad
Yes, I felt mine when starting from a stop until about 30. Then it’d smooth out a little, not much. Then I would get to 60 and it would vibrate and shudder. I could feel it in the seat the whole time. It was just worse at times than others. Keep in mind that with our off-roads, the shocks are stiffer, and I can definitely feel more bumps, etc., than what I felt in my 24 SR5. But overall, I’m pleased with the off-road and I’m loving the 6ft bed. And having the rear tires replaced and all four road forced balanced seemed to fix the issue, thankfully. Keep me updated. I’m curious to see if yours ends up being the same thing. Hopefully so, and it’ll be an easy fix. Best of luck to you.
Out of balance tires and out of alignment is not uncommon in 4th gens from what I see.
Slappy
tacoma , highlander
Out of spec on a new truck? Were you having vibrations?
yeah, it was a slight grabbing sensation with the steering wheel
new tires i always do a alignment anyway
but now there in no feeling in the steering wheel now
Gfenza89
Gary
2022 tacoma sr5
You know what Toyota is gonna do for you? Nothing……
Tacoscott24
Tennessee
2025 TRD OffRoad
So I figured I’d update and say that the dealership replaced my tires and said they road force balanced them as well. However, yesterday I got up to interstate speed around 80 mph and noticed that it would shake you in the seat more than the normal drivetrain occasional vibration. I checked on the rear tires the dealership replaced and rebalanced. There are literally no weights on the wheel whatsoever. You can see where they removed the original weights and never replaced them. I crawled under the truck and made sure they weren’t on the inside of the rim and nothing literally wheel and tire. No freaking wonder it vibrates like crazy. I thought it might’ve been the driveshaft, so looks like another trip back to Toyota for them to make it right. They would screw up a wet dream. I don’t know how they make it to work every day.
Gfenza89
Gary
2022 tacoma sr5
Incompetent morons…..and they think we the customers are as stupid as they are, that’s the worst part.
