Spin on oil funnels info please
Salt Lake Valley, UT
2024 Tacoma SR5, 2004 4Runner SR5, 2001 E55 AMG
Anyone have any idea what spin on oil fill funnel would work good with our trucks? I’m trying to avoid buying a universal one and can’t find anything specific. Any links would be most helpful as I’d like to get my oil changed soon.
saerandy
Randy
Virginia
2024 SR5
The APSG Locking Oil Funnel here https://amzn.to/3Gug0sm is the one you want.
Also suggest a moldable, foldable oil drain funnel (here: https://amzn.to/4lc1pAR) to wrap around the crossmember for when you take off the oil filter. Even though there's a lip and drain under the filter, it's too far back and drips oil on the crossmember. This redirects it and cleans up nice with a shot of brake cleaner. Don't forget crush washers if you don't already have some: https://amzn.to/3TUQ7Fc
Knute
2025 Off-Road Prem. 6MT, 89 Bronco 5MT, 69 MGB 4MT OD, 13 Outback 6MT
I cut the bottom off a quart of Mobil 1. Fits just fine in the oil fill tube. No additional cost. Regarding the use of a shapeable funnel when removing the filter, good idea - I drained more oil from that area than I expected. I bought the cheapest one I could find on Amazon - works great. One factory - lots of sellers.
Taco_Raider
Joe
Michigan
2025 Toyota Tacoma TRD Off Road
What kind of funnel do y'all use when refilling new oil? I performed my 1000 mile break in oil change last week and noticed that a skinny neck funnel was all I had that wouldn't make a mess, but it took forever to pour all the oil.
saerandy
Randy
Virginia
2024 SR5
Thanks @saerandy! I already have the formable one, which can stop a really nasty mess for sure.
I have never used a spin on oil filler, but that looks like a great idea and should save some time and possible mess too.
Ray T
Ray
24 tacoma pro
Recently changed mine and used the Toyota oil quart cut half off it screws into the oil fill perfectly
Pappy
Albuquerque, NM
I will second this. I used my flex funnel for the first time this morning on my third oil change. It worked as expected. No fuss. No mess. Combine this flex funnel with a Fumoto F103N drain valve and oil changes could not be easier.
