DRL Fang Lights randomly turning on
felixalva60
felix
Tampa
I bought these DRL Fangs for my Tacoma and they randomly turned on this morning for a couple minutes so I unplugged the fuse cap. Anyone got a fix or recommendations for this? I’m not a mechanic so I don’t really know how it works..
If you search, you'll find that there are numerous people mentioning this.
It is a result of the fuse that you connected the lights to and is completely normal as the truck energizes that circuit to run tests at certain intervals.
felixalva60
felixalva60
felix
Tampa
So it should turn itself off after how long? I keep looking for somewhere that says that but I can’t find it.
tomvb1
That's the best approach I've seen to prevent the issue since the USB2 circuit is separate from the one which comes on randomly. I may do that for mine some day.
I have grill LED and Fang lights on the INJ circuit in the driver's side fuse box which *is* a circuit which comes on randomly. I have had no issues at all with that and never saw any signs of battery drain.
I think they come on for less than a minute but have never tried to measure it so that's a gut feel.
felixalva60
felixalva60
felix
Tampa
Yeah I saw that a lot in this forum, I have purchased a switch panel since I have other stuff I want to wire so I’m just going to wire it to that ?
JimScotty0
The Farm, Central Washington
2024 Toyota Tacoma
Why not just wire it to the hot wire on the 3 pin headlamp harness? The ground and the signal power is there too. Then all your DRL's will work with the other OEM DRL lighting? That is what I did, and it works well with a bunch of DRL lighting I added.
felixalva60
felixalva60
felix
Tampa
I’m not mechanically inclined like that so I have no clue what you just said man ?
JimScotty0
2024 Toyota Tacoma
syrade
4th gen tacoma TRD offroad
JimScotty0
2024 Toyota Tacoma
That’s valid
I actually have the skills to make such harnesses and even much more complicated ones. Many years ago on one of my first jobs, I worked on Grumman F-14 electronics, wiring components, cables, and haness. I helped build many thousands of those awesome jet fighter components back in that day. All crimps and solder joints and even the number of twists per inch were examined by inspectors with magnification, and even had high voltage testing to ensure they were built to MIL specs. A component failure was not an option as it could jeopardise many lives and many millions of dollars. Every process and component had to comply with MIL specs. We had the MIL Specs books close by as reference that we used every day. Some of these huge harnesses had dozens of arms and some connectors had hundreds of all different size wires including some coax. They could be very short, or even 20 feet long. A single complex harness could take an expert many weeks to manufacture. Unfortunately many of the fighter jets we produced were sold to Iran. It was an enjoyable experience of which I learned many things.
Now I am retired, and I still built simple cables and modifications, but Aspire had a product that was quality built and was able to save me time and effort so I had no problem purchasing it. Just a small piece of all that I have invested in my 2024 Tacoma TRD Pro.
