Possible rear main seal oil leak
Gfenza89
Gary
2022 tacoma sr5
Good luck @rijc99! I hope your dealer is already making plans to fix those oil leaks.
Almost every week I find a new reason to suspect the quality and durability of my truck, which I do happen to love. I didn't hesitate to buy a first year Taco because of my history with Toyota, but my confidence is starting to crack.
Let us know how this goes!
Timing cover leaks are also becoming a thing with these 4th gen’s….so much for the 2 part timing cover preventing that leak lol.
rijc99
Yikes. Maybe I’ll have them look at that area just in case.
I’ve been looking for a coolant leak but haven’t found it yet. I can occasionally snell coolant when I exit the truck.
If the coolant is coming out of the engine, then I say it is new engine time. Hopefully it is just a line or a fitting, but with the oil leaks it does make you wonder.
Gfenza89
Gary
2022 tacoma sr5
Normal it’s the way Toyota designed the overflow bottle. The bottle degasses to the outside
Gfenza89
Gary
2022 tacoma sr5
Latest theory I have heard about most oil leaks where rtv sealer is applied is that it’s from contamination on the surface of the metal such as natural oils on the assembly line workers hands . Makes sense to me but you’d figure Toyota would have them wearing gloves but who knows
rijc99
If true it’s very reminiscent of how not clearing the engine blocks properly caused all those engines to eventually fail.
It basically comes down to sloppy production and assembly by the former masters of automotive perfection.
I just can't figure out what the hell happened to Toyota.
rijc99
Got my truck back but then had to send it back to Tustin Toyota a couple of days later since they did not tighten all four bolts on the transmission cross member nor did they tighten my transmission shield all the way.
Oh, then when I went to pick it up the service writer told me he’s worked with the tech for many years and he’s never made any mistakes before and they believe it was tight when it left their dealer and it was probably someone else that loosened it. Basically implying I did it.
I’m now looking for a new dealer to bring my truck to in the OC area.
Gfenza89
Gary
2022 tacoma sr5
No surprise to me…
I'm not really all that surprised that they forgot to tighten down those four bolts on the transmission cross member or fully tighten the shield plate. I should not have happened but people do make mistakes. I am amazed that they had the balls to say you sabotaged your own truck and loosened those bolts to make them look bad. I don't think they need any help there from your experience.
I agree - find a new dealer but I would follow up with Toyota since you have the pictures and ask them if they think you F'd up your own truck to cause trouble, and if this is the quality Toyota care that we are supposed to trust.
Coast
Oregon
2024 Toyota Tacoma Off Road
Noticed oil on the cross member. Had to take truck in to repair engine oil pan leak, was under warranty all good so far 12k miles
EatMyTaco
Murica
2026 Tard OffRoad
Well F, now I need to go look at that when I put my skid plate back on tomorrow.
rijc99
You might as well also check the rear main seal while you’re at it tomorrow. Right where the engine and transmisson come together.
