Trailhunter - passenger ditch light hitting snorkel
Hey guys - I got some kick ass Rigid 360s from SPV. The only issue is the passenger side ditch hits the snorkel when I open the hood. Even if I rotate it, it hits. All I can think to do is find a 2” piece of mounting hardware with a slot that I could use to shift the light toward the driver side by an inch (it would bolt into the Rigid bracket and then I’d bolt the light into that new piece of hardware to the right). If anyone has an idea where to get such a piece of hardware or if you have another solution, I’d appreciate it.
2024 Tacoma Trailhunter - passenger ditch light hitting snorkel IMG_7796
2024 Tacoma Trailhunter - passenger ditch light hitting snorkel IMG_7797
Can you flip the brackets to the other side?
My Cali brackets ride over the hood.
My son suggested that - they are so closely contoured to the hood and specific to each side, if that makes any sense, that I don’t think it will work. Also I like the visibility I get with it off to the side on the driver side.
Over the hood is a WAY better design.
Vidman
Rick
Mass
My cali brackets work perfectly with Baja designs squadron pros on them. The calis don,t have that nasty offset on them
tnjwinters
Tim
2017 Tacoma TRD Pro, 2024 Trailhunter 6’
@tacorancher, what brand did you buy.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
The hardware stores in my area are Lowe’s and Home Depot. You can try searching your hardware store website for Simpson Strong-Ties. I am seeing 20 gauge galvanized steel straps with holes as well as L brackets. These are normally meant for shelving or joining wood together, but I’m sure something will materialize that you could spray paint with black high temperature paint or have powder $$$ coated. I wonder if 4 Wheel Parts would have something like that intended for automotive projects.
A better first step might be to contact Rigid for a suggested solution.
My son and I went to home depot but could not find anything. I called @SPV Parts and we both were thinking of the exact same solution - a small, stainless steel powder coated piece of hardware with oval slots - I’ll post when it’s set up !!!! John at SPV is the best by the way!
Edit: thanks for the detailed recommendation @lauren01 - that was going to be my solution but if I can get something more fit for purpose and that will not rust will be ideal 👌
This little 3” piece of hardware (also Rigid) solved the problem entirely. Hood opens all the way without touching the snorkel. Is it aesthetically perfect? No. But it works and nobody will notice. Thanks @SPV Parts for helping me fix the issue!!!
2024 Tacoma Trailhunter - passenger ditch light hitting snorkel IMG_7911
2024 Tacoma Trailhunter - passenger ditch light hitting snorkel IMG_7915
2024 Tacoma Trailhunter - passenger ditch light hitting snorkel IMG_7912
2024 Tacoma Trailhunter - passenger ditch light hitting snorkel IMG_7916
lauren01
Lauren
Ventura, CA USA
Awesome!!! I hear all the good things about SPV 😍
That looks fantastic!
Loving the running light setup! I will put out a video on the installation process this weekend for anyone interested.
2024 Tacoma Trailhunter - passenger ditch light hitting snorkel IMG_7936
