Trd Pro / Trailhunter engine airfilter
Halifax, NS
2025 TRD Pro
Just replaced mine. If you disconnect the mass air sensor it’s super simple and quick.
The new filter only had a tiny bit of oil on it. I was tempted to add more, but I didn’t wanna mess with the OEM spec.
Not sure why unplugging the MAF would make it easier, it doesn’t interfere with anything, the process still sucks, here’s before and after 21k
2024 Tacoma Trd Pro / Trailhunter engine airfilter IMG_8564
If you don’t unplug it, you cannot pry the filter housing apart by more than 2 inches. If you unplug it, it comes right open and it doesn’t suck at all. It’s super easy.
Halifax, NS
2025 TRD Pro
Not really a fan of how much oil comes on the filter from the factory holy hell, it’s like they sprayed it inside and out, won’t be putting that much oil back on next time
2024 Tacoma Trd Pro / Trailhunter engine airfilter IMG_8566
2024 Tacoma Trd Pro / Trailhunter engine airfilter IMG_8565
Mine was almost dry! I had to touch the rubber part to really makes sure it had some oil on it. On the filter I could not feel any oil at all - but it was red so I guess it was oiled?
Halifax, NS
2025 TRD Pro
Yeah I washed all the red out of the pleats like I normally would with any filter like a foam motocross filter or a random k&n, I couldn’t believe the amount of oil floating inside when I was spraying the dirt out, I’ll let it sit out for a week or more to dry and I’ll oil only the outside
Oh - yeah - the filter in my truck was covered in oil like yours. The OEM replacement had a very light amount. So light that I wasn’t sure if I should add more.
Halifax, NS
2025 TRD Pro
They probably had to remedy the amount of oil at some point because of the failing MAF’s on TH’s, I sprayed cleaner on my MAF for good measure when I swapped, the oil is to keep moisture out, and maybe catch the dirt too I’m sure it’s oiled enough to perform as it should
just looked at your pic, it looks the same as mine, it’s good
Amorak
Oklahoma
2025 Tacoma TRD Pro, undergound w/ red interior
This filter is so strangely shaped, the air box is a complete pain in the ass to pull out filter and close on a Pro, clips buried way down.
..anyway, ordered a spare "K&N looking" filter from closest Toyota dealer I could during online Black Friday sale.... and... it's still not in. WTH!? Are they one offs only in Mexican factory (seemingly :sunglasses:).
I'd like to see aFe make a dry version... well, anybody to make a version at this point.
..anyway, ordered a spare "K&N looking" filter from closest Toyota dealer i could during online Black Friday sale.... and... it's still not in. WTH!? Are they one offs only in Mexican factory (seemingly :sunglasses:).
You need to unclip the MAS wire - opens up easy
Amorak
Oklahoma
It is awkward - lift the housing up and drag the filter downward and it pops out pretty easy
Have you been able or tried to order a spare? I think I've caught your videos on YouTube?
Edit: I see you have , from above.
Amorak
Oklahoma
Yeah! I picked it up from the dealer. I can make a video next time.
Ha! You must've grabbed the last one... as long as mine is taking to come in... :wink:
