315 70R 17 with 0 Offset wheel
jltk
Toyota Tacoma, BMW M3, Dodge Viper, Porsche 911
Hello all,
I am a new member, got my very first Tacoma (TRD Sport+ Manual) about 2 weeks ago. Nice to meet all of you.
I plan on building up my truck, and I stumbled across an ad on Facebook. A person is selling a 315/70R17 tire with 17x9 wheels with 0 offset for a reasonable price.
I searched the form here, but it doesn't look like it is the most popular setup for Gen 4 Tacomas.
Is anyone running this setup? How much trimming/alteration will be required to fit this on stock suspension?
Or do I need to add a lift kit to accommodate this size of a tire?
Thanks in advance!
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Quite of few people run zero offsets. I’m running 285/70/17. 315/70/17 will rub in the front but very slightly. You will need to remove the front fender felt and either push it up and or trim the felt off. Good news is it only rubs on the felt liner and not the plastic bumper.
jltk
Thanks a lot for your reply, Taco Ji.
It's great to hear that I don't have to do any major alterations. Sounds like just cut a bit of felt liner!
I assume that I would need to remove the crash pads towards the cabin on both sides of the front? And we are talking about the stock height without any lift kits, right?
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
This is zero offset. Expect about 1.7 to 2 inches from the offroad fenders depending on tires (more aggressive treads will be even more poke). Mine is 285/70/17 on trd off-road hybrid stock suspension no lift at all. From what I’m reading the hybrid trucks are slightly more lifted than standard turbo engines due to the extra weight. I didn’t remove the crash plate and this is the reason I went with 285 size instead of 315. I’m not sure but you may need to remove the plate.
2024 Tacoma 315 70R 17 with 0 Offset wheel E880F1F4-F64D-49BC-8CB4-839FA4DD6BAE
2024 Tacoma 315 70R 17 with 0 Offset wheel 48139DF7-2DA5-4F85-8819-4C69CA883E66
2024 Tacoma 315 70R 17 with 0 Offset wheel 37AEE5AD-3D68-4E0D-8C0F-5B52AD42A764
2024 Tacoma 315 70R 17 with 0 Offset wheel 176B4A28-0C79-48EC-BCAB-33FDD97AEF57
GMak621
Røgue Valley
26 Tacoma TRD ØR Hybrid
Hello all,
Thanks in advance!
Are the wheels hubcentric?
jltk
It is an aftermarket wheels, and it seems the manufacturer sells the specific hub centric rings for the applications.
jltk
That looks great!
Pappy
Intermountain West
Just so you know. Older wheels used 12mm lugs. Our trucks use 14mm lugs. Also, the center bore is different. You better make sure those wheel fit before you plunk down some cash.
jltk
Thanks a lot for the valuable insight.
I did check all those; hence, the wheels in question were from a new Chevy Colorado AT4.
The only difference was the center bore, but I contacted the wheel manufacturer to confirm that I can swap the hub ring.
Did all this research but did not hear back from the seller, so all for nothing lol.
So I am going ahead with icon wheels and 34”’ tires instead.
