Wiring grill light bar for a hybrid question
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
  • Thread starter
  • Banned
  • #1
Can someone who has done wiring for your hybrid truck let me know where did you connect your power red wire to in the passenger fuse box?
Also my power wire does not have the ring terminal so should I cut the end wire and add a ring terminal provided that I can find a power bolt to attach to? Appreciate any information
2024 Tacoma Wiring grill light bar for a hybrid question IMG_3764
2024 Tacoma Wiring grill light bar for a hybrid question IMG_3671
See my very detailed post about this. Simple search for DIY heritage grille and diode dynamics
Crazy Mary’s Husband
Chester
God’s Country, USA
You should have the proper tools and knowledge before attempting to play with electricity. Its not worth burning your truck up. Seek professional help. 👍🏻
Just trying to help a brother out.
Not sure why that power wire has that connector on it, but it looks like you need to clip it and put on a ring terminal that would install on that 12v post (provided that you can remove the nut and put the ring terminal under it.)
Taco Ji
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
  • Thread starter
  • Banned
  • #7
That’s why I’m here doing my research
Taco Ji
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
  • Thread starter
  • Banned
  • #8
Yes I already purchased a ring terminal connector like the negative ground wire. The problem I’m facing is I’m not 100% sure which draws power in the fuse box. ChatGPT says to connect to the clamp that is under the red plastic cover which per the owners manual says is used to connect jumper cables but there is no bolt to connect to.
This YouTube video suggests to connect to the highlight bolt in this photo but I’m getting contradictory information online.
start at 1:22
2024 Tacoma Wiring grill light bar for a hybrid question IMG_3760
StreeTaco
2024 Tacoma TrailHunter
I’ll try to help you bro.
This is just my opinion-
First option-
Get a 12v test light
Look for switched power on either an empty fuse slot (optimal) or an occupied fuse slot(acceptable )that matches the rated fuse amperage of your light bar
Install the proper fuse tap into this slot
Wire it up!
Second Option-
Wire the light bar to an always on source
Use test light to confirm the big bolt (highlighted in your pic) is a constant source
Ring terminal under nut
2024 Tacoma Wiring grill light bar for a hybrid question IMG_0073
2024 Tacoma Wiring grill light bar for a hybrid question IMG_0074
Taco Ji
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
First option-
Wire it up!
Second Option-
So essentially I need to grab a test light to confirm if the highlighted bolt has constant power and if confirmed add the ring terminal connector to the red wire and connect it to the bolt and wire the black to the chassis for ground and it should be good to go!
If you're going to get into electrical work, it's best to invest in a decent multimeter so that you can test voltage and amperage and cement understandings of the basics.
That way you can easily set the meter to check DC voltage and start checking your potential attachment points without shocking yourself, knocking yourself out, or screwing up something expensive in the truck's electronics and systems.
If you screw up plumbing, it's often messy, but rarely deadly.
If you screw up electricity (or gas fitting for that matter), it's very easy to be deadly situation.
I applaud the questions, but ChatGPT is not an expert and please make sure that if you are not 100% confident you've got it (and you know what can go wrong if a step isn't performed correctly), STOP and get experienced help.
Taco Ji
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
What? I’m only trying to confirm if that bolt is a positive power or not.
Lol just get a multimeter and put the red probe on the post and the black one on a ground. That will tell you if it's powered which I guarantee it is.
Taco Ji
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Yup. That is my plan. Thanks for taking the time to help.
StreeTaco
This is getting a tad ridiculous
