How to break in a new Tacoma? Other tips welcomed :)
ohhkk
Sacramento
Honda Civic
Just got me a 2026 long bed mid bath off road premium!!!
im sitting at about 150 miles and realized im not sure how to properly break this in. Does anyone have any tips? Anything I shouldn’t do? What gas do yall recommend 87 or 92? Anything I should do immediately?
MustardTiger
TacoMAX/SDuty/Dmax
Change your oil/filter after 500-600 miles. Don’t set the cruise and drive for hours on the interstate at one speed; variate your speed. Avoid full throttle/foot to the floor acceleration events, especially from a dead stop, until after 1000-1200 miles. If you can, put the engine under load (long highway grade incline), and do some acceleration pulls at speed, approaching redline, then letting off. Use manual shift mode to limit upshifts.
bitflogger
WI
1. Follow the directions in your owner's manual.
2. The top tier fuel spec and not octane is the important matter for the fuel you choose. During the break in period you should not be accelerating hard or pulling loads that are the circumstances where the delayed combustion from higher octane is a possible advantage. After break in there are times when higher octane is helpful, but the vehicle runs great with standard octane fuel.
TimC.
Tim
Ridgeway, VA
2024 Toyota Tacoma
Strongly disagree with taking it easy on the new engine. No towing for sure, however, you must seat the piston rings and you have only one shot at doing it correctly. The rings must be push out to the cylinder walls. This can only happen under load such as a dyno simulation. Cylinder pressure must be increased. Get your oil analysis done. Speed diagnostics is a great start to use data to determine break in and not opinions. Use Toyota oil until broke in which can take up to 10k miles monitoring total ware metals, and partical size. Oxidation value you will see just how good or bad the oil is performing. Switch to Driven DI 20 after data says the engine is broke in. Learn all you can and quickly about your lubrication program. Much has been written on this topic here. Check out the motor oil geek on YouTube. If you're not trying to get all you can out of this truck just do as the masses do and follow the owners manual.
lane47
Lane
Tennessee
2025 Tacoma
No hard braking
no rapid acceleration
no driving at constant speed of 50, 60, or 70 for over 10 minutes at a time
change oil at 1000, then every 6 months or 5000
Yotota
SW WA
24 TRD
On a short lifespan race engine, the full-bore 100% force break-in method is sound. These trucks are not race engines.
The engine has already been heat cycled with all the loading and unloading, so that initial part is done.
Drive it moderately for the first 1k miles. No towing, no cruise, vary the RPMs. Keep it below half throttle or so. This is pretty much what the manual says to do.
Once you hit 1k miles, put it in Sport mode and do some full throttle freeway onramp pulls. It's worth the wait. 😎
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Dont listen to these guys….
Do read your manual on break in period.
Don’t change your oil at 500 miles and every 1,000 miles. Change it per Toyotas recommendation which is 10,000 miles.
Don't forget to drink your ovaltine and get your vaccinations too!
Crazy Mary’s Husband
Chester
God’s Country, USA
Read the manual, put gas in it and enjoy your new truck. 👍🏻 Toyota knows what they’re doing.
TimC.
Tim
Ridgeway, VA
2024 Toyota Tacoma
Yeah, you should do exactly like the manual and this cat. Wow? 10,000 mile oil changes with all that metal floating around? Criminal and I have the data to prove it if you want to contact me off line. I'll show you how to get you oil analysis done and let the data determine when the engine is broke in.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
This must be your first car. I have a 2015 BMW X5 that I only change once a year with synthetic oil… that 10 year old suv is still in excellent condition. Those metal shavings you found isn’t going to change when you change an oil that is at the same that youre removing and adding at 500 miles.
TimC.
Tim
Ridgeway, VA
2024 Toyota Tacoma
Show us the data. Listen carefully. If you do not break in the engine properly, it doesn't mean it will blow up or perform bad. It means the engine piston rings will seal good which means you have a truck that's going to burn oil. How much determines on how bad the seal is. If you don't mind that, do as the manufacturer says.
Consider this, after you drive the truck and park it. Where does all the 0W-20 go thats in the turbo? It stays there and bakes.
If you don't think your engine is not going to burn oil between 10k mile oil changes, measure it.
