CAMTuning
Cameron
New Mexico
2025 Tacoma TRD OffRoad
Knock • Fuel • Boost • Torque — Learn the Language of Power
This is a Tuning Fact series designed to open up the hood on how your Toyota actually thinks. Each post breaks down real parameters and real log examples so you can make sense of available data, and understand the importance of having a way to access it.
This isn’t about scare tactics or shaming off-the-shelf maps—it's about awareness. When you understand what “healthy” looks like in a log, you gain control. You stop guessing (you don't know what you can't see). You start catching issues early and get the most from your mods and tune.
Discussion is encouraged. Bring your questions, bring your curiosity. If you want power, reliability, and consistency, it helps to know what your ECU is asking for—and what it’s actually getting. That’s where tuning stops being a mystery and starts being a tool.
CAMTuning
CAMTuning
Cameron
New Mexico
Session 1:
What “-3.0° Knock Correction Angle” Actually Means (And Why It Isn’t Bad)
Most people are used to thinking that any knock number = danger.
On the new 2.4T Tacoma / 4Runner, that’s not actually true.
The Short Version
On this platform, -3.0° of Knock Correction Angle (KCA) = the baseline.
It’s not knock. It’s not a problem. It’s not timing being removed.
It’s the ECU’s neutral position — the engine’s “zero.”
Think of -3.0° as the truck saying:
“We’re good. This is where I start making decisions.”
When KCA Moves More Positive (like -2, -1, 0)
The ECU is:
  • Adding timing
  • Seeing clean, stable combustion
  • Responding to good fuel quality
  • Essentially rewarding you
This is what good 91/93 octane should look like on a healthy tune.
When KCA Moves More Negative (like -5 to -10)
The ECU is:
  • Removing timing
  • Hearing noise/instability it doesn’t like
Possible causes:
  • Lower quality fuel / 87 octane
  • Heat-soaked intake temps
  • Too much boost for current conditions
  • Tune or mechanical issue
Note: Some timing pull during shifts is normal — don’t panic.
This doesn’t automatically mean engine damage.
It means the ECU is protecting you.
Why You Should Care
Because the ECU is already tuning your truck every time you drive.
You don’t need a dyno.
You don’t need to be a tuner.
You just need to look at the data.
Logging tells you:
  • If your fuel is helping or hurting (87 vs 91/93)
  • If your octane is actually what the pump advertises
  • When heat or elevation is costing power
  • If the tune is giving the ECU what it needs
What To Do This Week
If you’ve got an Accessport, run a quick 3rd-gear pull and look at:
  • Knock Correction Angle
  • Intake Air Temp
Not ready to log? No pressure.
Start paying attention. Ask questions. Stay curious.
We all start somewhere.
Closing Thought
You don’t need to be a tuner to understand your truck.
You just need the right things to look at.
I’ll be here regularly breaking down:
Knock control & octane
  • Torque & load limits
  • Gear-based torque mapping
  • Fueling strategy
  • Boost control behavior
  • And how all of this affects your seat-of-the-pants power and driving experience
If You're Curious
I’m CAMTuning — I remote tune the 2.4T Tacoma & 4Runner platform with Cobb.
If something in your logs doesn’t make sense, DM or post it.
We’ll figure it out together.
Question:
What fuel are you currently running, and have you ever checked your knock numbers?
CAMTuning
CAMTuning
Cameron
New Mexico
To go one step further from above, here's an example of a data log with limited parameters shown:
  • Intake air temperature (at the intake and at the manifold)
  • Engine speed
  • Knock correction angle
you can see the knock correction angle (yellow line) moves around -3, dips, then climbs to close to -2, but it also dips down to -3.8 on shift. The way to read this is to follow the RPM scale (white line) to where it peaks and then drops off, and that indicates a shift point.
The KCA in this log is what would be considered normal and would not be cause for concern.
2024 Tacoma Tuning Facts - Understand Your Truck Like We Do at CAMTuning 1766781245300-of
Turbo_Tacoma
Zach
New Mexico
2024 Tacoma 6MT
Subscribed!
I've been waiting for something like this, Cam
Really appreciate your approach and thoughtfulness for this platform
Also, my truck is sooo much more fun to drive now. Feels super healthy - best way I can describe it
Finding myself making excuses to grab the keys and now I finally get to log my truck while I'm driving for work!
daneg6
Daniel
2026 Tacoma Trailhunter, 2025 Lexus Gx550
Watching to see if I should pull the trigger on an ap. I had an AP with my 05 sti which was fun but ultimately I blew the engine. This time around don’t really need the power but I will be watching for drivability improvements.
Turbo_Tacoma
Zach
New Mexico
2024 Tacoma 6MT
Are you located near New Mexico, El Paso, or Colorado?
Happy to let you test drive mine so you can check it out for yourself 👍
CAMTuning
CAMTuning
Cameron
New Mexico
Drivability is first, power is 2nd. You'd be amazed what tuning does for where the truck lives in 10-40% most of the time. I rarely go WOT in my truck because it's so responsive around town and on the freeway.
Airborne
Upstate,NewYork
This some great info, much appreciated, few minor questions ,
does the tune also apply to Hybrid?
Do i need to come to your shop, im in upstate New york.
What is the cost of having a tune done on my truck
thank you David
CAMTuning
CAMTuning
Cameron
New Mexico
thank you David
This does also apply to the hybrid, and we have tuned many of them over email all over the country and some on our dyno locally. You absolutely do not need to come to our shop to do it, and you will have one-on-one support to install, data log, and receive revisions while we custom tune your truck. I will PM you details on pricing and procedure.
Turbo_Tacoma
Zach
New Mexico
2024 Tacoma 6MT
Just got back recently from a ski trip to Wolf Creek and was able to monitor the truck all the way up the pass at 11,000+ feet
I've had this truck on some sort of 'tune' for most of its 50k mile life but not until I had the accessport was I able to check how things were looking at altitude and on super long climbs. I was worried that I might be exposing it to damage during moments like this previously (maybe I was who knows).
I had the scary experience of realizing years ago that my Evo's factory calibration included tons and tons of knock and was super rich - been nervous of factory tunes ever since.
This time I was watching and noticing around 14.5 afr during light throttle then dipping to around 13-12.7 when I gave it a little more to pass (maybe 40-50% throttle).
Knock correction angle went from -3.00 to 2.9 and then back to 3.0 which was a relief
Even back when it was stock I always worried I'm pushing too hard on that climb because it's long and steep and the air is thin but apparently now I'm babying it for no reason!
Shot from our first trip of the season 👍
2024 Tacoma Tuning Facts - Understand Your Truck Like We Do at CAMTuning IMG_6935
Pappy
Intermountain West
Ditto. I have a mini adventure coming up and I really want to take the Tacoma. It's just too fun to drive. Alas, I'll be taking the old 4Runner (1985, 3RZ transplant, supercharged) to keep the miles off the Tacoma. Plus, there is one road that might challenge the Tacoma, and the 4R will walk right through it. At least the 4R is supercharged, which puts a few grins on this old mans face.
CAMTuning
CAMTuning
Cameron
New Mexico
Session 2:
What “15.0 Knock Control Learned Value” Actually Means (And Why It Matters More Than You Think)
Most people watch their knock numbers, air fuel, and timing…
but they miss the value that quietly controls how aggressive the ECU is allowed to be.
In this platform, that's the KCLV — Knock Control Learned Value.
The Short Version
15.0 KCLV = the baseline(resets to this on learning reset).
It’s not “good” or “bad.”
It’s simply where the ECU starts.
From there, the ECU learns.
  • Higher than 15 (like 17–20) →
    “We’ve got safe combustion. I’m confident. Let’s run more spark.”
  • Lower than 15 (like 13–14) →
    “I’m hearing borderline knock or noise. I’m going to be cautious.”
KCLV doesn’t change timing directly.
It sets the ceiling — the confidence limit — for how much timing authority the ECU is willing to use.
Think of KCLV Like a Trust Score
15 = Neutral
18–20 = Trust earned
13–14 = Trust lost
It’s the ECU deciding:
“Can I trust the fuel and conditions enough
to apply the timing this tune is asking for?”
When KCLV Climbs Above 15
You’ll typically see this with:
  • Good 91/93 octane
  • Cool air temps
  • Clean combustion / no knock noise
  • A tune that the ECU “likes”
This is ideal.
It means the ECU has timing headroom and will use it when conditions allow.
This is where a custom tune + good fuel actually feel different on the road.
When KCLV Drops Below 15
The ECU has seen something it doesn’t like:
  • borderline knock events
  • inconsistent fuel quality
  • heat-soaked conditions
  • mechanical noise that sounds like knock (false knock)
It reduces its trust in the ignition strategy.
The result?
  • Less timing authority
  • Less power potential
Not always dramatic — but absolutely worth paying attention to.
Why You Should Care
KCLV is how the truck tells you:
“Can I do what this tune is asking me to do?”
This is where tuning and driving conditions intersect.
Even the best tune can’t force the ECU to be confident when the fuel isn’t supporting it.
If you want consistent performance:
  • Have your tune developed for the fuel that you intend to run
  • Watch KCLV trends
  • Watch fuel quality
If you’ve got an Accessport, log:
  • KCLV
  • KCA (Knock Correction Angle)
  • Intake Air Temp
  • Note what fuel you're running.
Look for the trend:
  • KCLV rising after a fill-up? → Good fuel.
  • KCLV dropping during heat soak? → Normal.
  • KCLV stuck at 15? → Needs more data; no confidence change yet.
  • KCLV falling over multiple pulls? → Start asking questions.
Just start paying attention. Ask questions. Stay curious.
Closing Thought
KCLV is the missing context for manyTacoma owners.
It makes the difference between:
“My truck feels inconsistent”
and
“I understand why my truck behaves differently day to day.”
Once you understand KCLV and KCA(covered in session 1),
you understand what the ECU is thinking
I’m CAMTuning — I remote tune the 2.4T Tacoma & 4Runner with the Cobb Accessport and Protuner Software.
If you see KCLV moving and don’t know why,
post a log or DM me.
Question:
What octane are you running, and does your KCLV ever move off 15?
(If you haven’t checked yet, that’s totally fine — you’re in the right place.)
CAMTuning
CAMTuning
Cameron
New Mexico
Session 3:
What the ECU Is Doing When You See Throttle Closure
Sometimes when you’re reviewing a log, you’ll notice something that doesn’t quite match what your foot is doing.
The accelerator is down…
but the throttle isn’t fully open.
That can raise questions — especially if you’re new to looking at ECU data.
Let’s clear it up.
The Short Version
On the 2.4T Tacoma / 4Runner, the throttle is not a direct link to your foot.
It’s a torque management device.
This is not unique to Toyota.
Modern Ford and Volkswagen platforms use the throttle the same way — even at wide-open pedal.
The ECU uses throttle position as one of several tools to deliver the correct amount of torque for the current conditions.
Seeing throttle movement in a log is normal ECU behavior, not a problem by itself.
What Throttle Closure Is (And Isn’t)
Throttle closure is:
  • A normal torque control strategy
  • Used across modern OEM platforms
  • Part of how the ECU keeps power smooth and predictable
Throttle closure is not:
  • A malfunction
  • A sign of engine knock
  • The ECU “fighting” the tune
  • Something unique to tuned trucks
If you’ve logged a modern Ford or VW, you’ve seen this before — even on factory or OEM-performance calibrations.
Why the ECU Uses the Throttle
The ECU is constantly balancing:
  • Requested torque
  • Available airflow
  • Operating conditions (gear, speed, temperature)
  • Drivetrain protection
If delivering more airflow would exceed its internal torque model, the throttle is one of the cleanest and fastest ways to stay in control.
Spark, boost, and throttle all work together — the ECU simply uses whichever tool makes the most sense at that moment.
How This Relates to Knock Learning
Knock control and torque control are closely linked.
If the ECU becomes more conservative under certain conditions, it may adjust torque delivery.
Throttle position is one of several ways it does this — alongside spark and boost control.
This doesn’t mean knock is occurring.
It means the ECU is managing output intentionally.
If you notice throttle movement in a log, look at it in context:
  • Throttle angle vs pedal position
  • Gear
  • Intake Air Temperature
  • KCLV and KCA trends
Single events don’t tell much.
Patterns do.
Closing Thought
Throttle closure isn’t something to eliminate.
It’s one of the tools modern ECUs — Toyota, Ford, and VW alike — use to keep power consistent, smooth, and repeatable in the real world.
Once you understand why it happens,
it becomes useful information — not a concern.
CAMTuning
CAMTuning
Cameron
New Mexico
Session 4:
Fuel Trims, Rich vs Lean, and Why Boost Changes Everything
Fueling is one of the clearest windows into how healthy a calibration really is—if you know what you’re looking at.
Modern Toyota ECUs manage fuel using two main correction layers:
Short-Term Fuel Trim (STFT)
Fast, real-time adjustments used during light-load, closed-loop operation to keep fueling on target.
Long-Term Fuel Trim (LTFT)
Slower, learned corrections that reflect how the engine typically behaves over time.
Together, they tell you whether the ECU is making small refinements—or compensating for a deeper mismatch.
Rich vs Lean (in simple terms)
  • Lean = less fuel than expected
  • Rich = more fuel than expected
Neither is inherently wrong on its own. What matters is where in the operating range it happens.
At cruise and light throttle, the ECU intentionally targets an efficient mixture and uses trims to stay there.
Under boost, the strategy changes.
Why enrichment under boost matters
As load and cylinder pressure rise, combustion temperatures increase. To protect the engine and maintain consistent torque, the calibration transitions away from trim-based correction and into a commanded enrichment strategy. At this time the fueling target will become richer (.75 to .85 lambda: 11-12.5:1 AFR on gasoline).
  • There are no short-term fuel trims under boost
  • The ECU relies on modeled airflow and commanded fuel targets
  • Any learned long-term fuel trims can still be carried into higher load
If those learned trims are large, they can unintentionally influence fueling where accuracy matters most.
A healthy calibration:
  • Has minimal long-term correction
  • Transitions cleanly into enrichment
  • Delivers predictable fueling under load without chasing compensation
Discussion encouraged:
What questions do you have about fueling, trims, or air/fuel behavior that you’ve never gotten a clear answer to?
CAMTuning
CAMTuning
Cameron
New Mexico
Session 5:
Shift Schedules: RPM vs Output Shaft Speed (And Why Your Truck Feels the Way It Does)
If you’ve ever thought “this truck should’ve shifted already” or “why did it short-shift there?” — this post is for you.
Most people assume automatic transmissions shift purely based on engine RPM.
In reality, modern Toyota transmissions care much more about Output Shaft Speed (OSS).
What’s the difference?
  • Engine RPM tells you how fast the engine is spinning.
  • Output Shaft Speed tells the transmission how fast the vehicle is actually moving through the gears.
OSS accounts for:
  • Gear ratio
  • Torque converter behavior
  • Tire size
  • Load
  • Throttle input
That makes it a far more reliable signal for deciding when to shift.
Why this matters for drivability
Because shift schedules are often based on OSS:
  • Two pulls to the same RPM can shift at different road speeds
  • The truck may hold a gear longer under load, even at the same RPM
  • Light throttle can cause earlier, smoother shifts
  • Heavy throttle can delay shifts without increasing RPM targets
This is why changing engine power alone doesn’t always change how the truck feels to drive.
What tuning can (and can’t) influence
A refined calibration aligns:
  • Torque delivery
  • Throttle behavior
  • Shift timing
When these agree with the OSS-based strategy, the result is:
  • Fewer “busy” shifts
  • More predictable downshifts
  • Better part-throttle smoothness
  • A transmission that feels like it’s anticipating your intent
Have you noticed situations where the truck feels like it “should’ve shifted” but didn’t—or shifted when you didn’t expect it to?
