BRIDGESTONE DUELER A/T ASCENT
Norsk
Greg
Downingtown, PA
Anyone have tried BRIDGESTONE DUELER A/T ASCENT yet?
I am looking at replacing my falken wild peak AT4W 285/70/17. Why? I am doing 90 miles commute on highway every day.
bigd9247
Dalton
2024 TRD ORP, 2018 F150 XLT
What size are you planning to get? If you're planning to stay with 285/70R17 then it looks like those Bridgestones only come in an E-load range which will be heavier than your current AT4W's. I think the extra weight would decrease fuel economy.
Compherh
Sam
Miami
2025 tacoma limited hybrid
I have dueler ascent, but in 275/70 r18. They are a little heavier than stock, no humming, rolls good around corners. Got them from costco, not cheap $318 each, free balance/ install. 60k warranty. Lost 2mpg from stock.
Norsk
Norsk
Greg
Downingtown, PA
Actually, they weight the same. My falken is SL and it is 53 lbs. I am looking at Toyo Open Country AT III.
907Yota
Marty
Alaska
1985 Toyota Xtracab 4WD, 1990 4Runner, 2025 4WD Xtracab
I’m getting those installed on my 2025 today at Costco. I’ve run KO2s on my prior Toyotas. I decided to try something new this time around. I can update in a few days after some winter driving in Alaska.
2024 Tacoma BRIDGESTONE DUELER A/T ASCENT IMG_9565
bigd9247
Dalton
Good catch! I saw E-load and assumed heavier, but I forgot just how heavy the AT4W's are.
Tacohunter2024
Upstate New York
'24 Off-Road Premium Black
Wondering if they're still treating you well? I have a 2024 Tacoma Off Road with 47k on the original tires, but I am skating in the snow and slush this winter. I found a great deal on a set of TRD Pro wheels, I want to put these Dueller Ascent ATs on them, LT275/70/R18.
Also, perhaps more importantly, did you go white letters out? I have a black truck, now with the black wheels, I feel like I want to break it up a little.
Compherh
Sam
Miami
White letters in. I had KO2 on an F150 and it rode harder than brudgestone dueler.
2024 Tacoma BRIDGESTONE DUELER A/T ASCENT 20251109_111944
shackley
www.swxrflab.net
Those tires are heavy too.
shackley
www.swxrflab.net
If you want to stick to SL, the Toyo Open County AT III EVs are only about 44 lbs.
PNWkip
2025 DCLB SR5
My wife's Wrangler had OEM Bridgestone Dueller ATs and we just replaced them at 50K. Probably could have gotten more, but we go through passes regularly. Really liked them! Took them all over the place in the mountains, over passes, across the country, service roads, mud. Couldn't tell if they were loud because, well, Jeep, but we liked them!
I have 275/70R18 Yokohama Geolandar A/T4 on my Tacoma. True 33". SL. 3 peak rated. 43 lbs. A little bit of hum between 35-45 but really comfy tire. Not overly aggressive. $262 ea @ discount tire
2024 Tacoma BRIDGESTONE DUELER A/T ASCENT 767
PNWkip
2025 DCLB SR5
My wife's Wrangler had OEM Bridgestone Dueller ATs and we just replaced them at 50K. Probably could have gotten more, but we go through passes regularly. Really liked them! Took them all over the place in the mountains, over passes, across the country, service roads, mud. Couldn't tell if they were loud, well, because Jeep, but we liked them!
I have 275/70R18 Yokohama Geolandar A/T4 on my Tacoma. True 33". SL. 3 peak rated. 43 lbs. A little bit of hum between 35-45 but really comfy tire. Not overlay aggressive. $262 ea @ discount tire
Looks like Yokohama Geolandar A/T4 in 285/70R17 SL are 44 lbs /$286 per tire, 33" OA diameter. Worth a look!
907Yota
Marty
Alaska
After year s of BF Goodrich KO2s, I went with the Bridgestone on my 2025 Tacoma. I would say they are a little bit quieter on the highway than the KO2s. I found the BFGoodrich a little better on ice, but I think the Bridgestone is as good or better in the snow. I also stayed with the stock size as I’m trying to maintain the best mileage possible. 245/70/17.
2024 Tacoma BRIDGESTONE DUELER A/T ASCENT IMG_1054
2024 Tacoma BRIDGESTONE DUELER A/T ASCENT IMG_0299
PNWkip
2025 DCLB SR5
I really love how those stock wheels look on the silver SR5. Just looks good!
