2024 TRD Pro Battery Type
shackley
www.swxrflab.net
Good question. I think the manual says to do it on the battery but that terminal under the hood is for jumping the truck, so I don't see why it wouldn't work.
That's my assumption as well. When I have time to hang around, I'll try it, but if I'm charging when I'm away, I'll do it at the battery.
jackvz
Jack
richmond
2025 Tacoma Trd Pro
So nobody has hardwired it from the backseat to a plugin? That way you can simply insert an extension cord into the male receptacle, without having to open hood or backdoor/lift back seat. Using one of these:
gpburdell
GA
3G Tacoma
Sure, if you want to dedicate the trickle charger to the truck and leave it in place, just plugging in the AC cord via that mount.
Better IMHO to either use a ring-terminal pigtail like this one: https://www.amazon.com/Battery-Tender-081-0069-6-Terminal-Disconnect/dp/B000NCOKZQ
I used to use that for motorcycle battery charging, and now use it for the waverunner.
Or if you prefer a bulkhead mount rather than a pigtail, there's this: https://www.amazon.com/Battery-Tender-Quick-Disconnect-Cable/dp/B0DSM123QD
(and I still think it's ridiculous to have to put a modern vehicle on a trickle charger unless you're leaving it sit for 3+ weeks at a time)
shackley
www.swxrflab.net
That's pretty cool. I'll check to see if you can attach it to the wall near the battery under the back seat. If so, I have a NOCO Genius 5 that might fit in with the battery. It's not too much of a pain to raise the back seat to charge, but this would be much easier. Our RAV4 Prime is a bigger hassle to get to the battery, and the RAV manual states that the negative has to be removed for charging - weird.
shackley
www.swxrflab.net
I always charge mine under the hood. Have never had issues. It's currently charging that way for the next 2 months.
Check out JackVZ's post here about the NOCO adapter, although I'm not sure where you'd put it. I'm thinking of putting it on the wall by the battery under the back seat.
I have used battery maintainers for years on cars that I didn't drive in the winter. None of them were ever charged with the negative wire unhooked, but then none of them were hybrids.
jackvz
Jack
richmond
2025 Tacoma Trd Pro
Curious if it would fit. And then somehow run that cable to the bed and mount on the cab wall or side wall for easy plug in
shackley
www.swxrflab.net
Thanks. That's what I thought. It also fits in our 2023 RAV4 Prime.
Tom Sellick
Ontario
2024 TRD Pro
Do you charge the battery directly in the back? It would be slightly more convenient to do it under the hood. We'll see if the guy in Ontario has problems charging from under the hood. I expect you're right.
So I can confirm. Put the truck on the Nocco Genius 10 for 61 days under the hood at the jump point. Started up no problem and everything seems fine. Went for a drive and no issues.
Cool, and It only makes sense to charge from that jump point, I have never disconnected the negative cable when charging a battery, so neither of those recommendation in the manual make sense to me.
