I finally did a real-world side-by-side test between the 4th Gen Tacoma Trailhunter factory onboard air and a serious aftermarket air system after multiple trail days — and I honestly didn’t expect the outcome.
I actually like Toyota’s onboard air for convenience. It’s clean, integrated, and always there. But when you factor in air-up time at the end of a long trail day, the difference becomes a lot more noticeable than I thought.
I tested:
The results weren’t bad for factory… but once you compare airflow and total time, it changes how you look at onboard air vs aftermarket.
If you own a Trailhunter, air down regularly, or are deciding whether factory onboard air is “enough,” this is worth seeing before you commit either way.
Full video with real timing & setup:
Curious where everyone lands on this:
Factory convenience or aftermarket speed?
Drop your thoughts below — especially if you’ve run both.
— SmokyMtnTaco
YouTube: https://www.youtube.com/@SmokyMTNTaco
ALL Tacoma. ALL the time.
I tested:
- Same truck (2025 Tacoma Trailhunter)
- Same tires
- Same target PSI
- Stopwatch timing
- Best-case setup for factory air (4-tire hose)
— SmokyMtnTaco
